Results 1 to 8 of 8
    Jul 2011
    been planning to change my lug nuts mga ser,
    1. whats the difference between the alluminum ones vs the metal ones? does it has something to do with rusting?yun po bang lug nuts tlga yung nag ra-rust or yung stud bolt yun?
    2. the difference between the short lugnuts vs long or extended lugnuts?
    3. difference between colored vs chrome/stainless lugnuts? (do the colored ones fade due to long use or being old nuts)
    recommend p0 kau or comment..
    thanks tsikoteers!
    [i have the same topic at brakes,steering, wheels,suspension, pa delete nlng kung saan po yung wrong section]
    Quote Originally Posted by poochie02 View Post
    aluminum lugnuts don't last very long. Aluminum is soft so using aluminum lugnuts will just result in stripped threads sooner than later. Also aluminum expands more than steel when heated. This will result in the aluminum lugnuts working their way loose simply with the heating/cooling cycle of your wheels which is unsafe.
    Jul 2011
    tnx sa reply ghosthunter
    still waiting for other replies regarding my other question/s..
    Jul 2011
    Same reply as GH's if you hve a choice avoid the aluminum.
    Jul 2011
    Quote Originally Posted by Bin Diesel View Post
    tnx sa mga reply.. keping this thread baka may ibsang sumagot pa..
    Feb 2011
    alums vs metals? alums are lighter
    rusting? nah, lighter alums are race intended
    avoid open ended lugnuts, alums or non, they re prone to rusting.
Questions about lugnuts(copies lng)
