Results 1 to 10 of 21
February 27th, 2007 06:40 PM #1
hi guys, tnx in advance sa mga magrereply dito pero i'm just wondrin regarding sa mags sizes, i know a bit on how to read and understand about tire sizes but sa mags, hindi na. i'm planning to change my stock mags for my altis 1.8 seg lovelife body to 17 inches, kakasya po ba nag 205/50/r17 and what po ang exact size ng mags na sukat para dito 17x ?? i don't know. tnx.
February 27th, 2007 07:06 PM #2
February 27th, 2007 07:39 PM #3
oic, so un po sa 205 /45 r17 poano po sir mamar ung tamang size ng mags dun kasi d ako marunong umintindi ng sukat para sa 20545/r17, 17x?? ano po?
February 27th, 2007 09:50 PM #4
may tire calculator somewhere dito sa tsikot bro. try searching for it na lang at baka makatulong sa iyo iyon
hth
February 27th, 2007 11:33 PM #6
additional ? lang...
di nga ako kasi marunong sa mags sizes, could you pls tell me the exact size of tire thatwould fit this size:
size: 17 x 7.0
offset 38
holes: 4
pcd: 100
thanks ulit in advance
its for the lovelife body corolla
nachek ko na sa tire calculator ung 205/45/r17 na suggested ni sir mamar and it only increased about 4-8% sa stock size so i think(correct me pls kung mali ako) ayos ba un?
February 28th, 2007 12:16 AM #7
size: 17x7= 17 inches ang diameter ng rim/mags at 7 inches ang width
offset:38= ito yung measurement ng mags, distance from your stud bolts, the higher the offset mas lalabas sa body ng car yung tires, the lower number mas papasok sa loob ang tires(or the other way around hehehe).
Holes:4 = no explanation necessary
pcd:100= distance of one hole to another, in milimeters. ex pag pcd110 mas malayo mga butas sa isa't isa
hope to help
February 28th, 2007 12:23 AM #8
btw bro, sa ganyan kalapad na mags baka mag rub sa fenders mo ang tires. Yung dating corolla ae101 ko naka 205/45 r16 lang nag rub na sa fenders pag may sakay sa likod. sa lovelife na body mas maliit pa ang clearance ng fenders kaya baka mag negative camber ka pa just to fit the tires. ang optimum increase in overall diameter mga 1-2% lang. 4-8% is too much, babagal na acceleration mo due to the larger diameter not to mention madaling masira suspension components due to the heavier weight. Thats just my 2 cents.
February 28th, 2007 12:32 AM #9
tnx sa reply
ah ganun ba sayad, tnry ko ung 205/40/r17 sa tire calc, pareho lang sukat sa stock na 185/65/r14.
February 28th, 2007 12:37 AM #10
and about dun papala sa 17x7 na un ano exact tire size para dito, about sa tire add info ko sa side lumapad cya ng estimate ko ulit by 5,10 or 15mm...
gusto ko lang maliwanagan. are you referring to Hitman query? kasi iba ang intindi ko sa tanong ni...
2022 Toyota Fortuner
