Results 1 to 10 of 63
Threaded View
August 2nd, 2017 09:58 PM #10
Eto ang gamit ko (bought at Ace for around Php1,7k):
Have only used it for topping up so far. Wala siyang deflator so kung na-overinflate ka sa gas station air fill-up, manually mo muna siya babawasan ng hangin saka inflate to your preferred psi. Features include the digital tire pressure gauge and a 5V USB outlet for charging your electronic devices, though you still need to plug it to your car's 12V cigar lighter outlet.
Cons include the 40~50 psi max pressure and not being able to inflate from flat. Haven't tried to inflate a flat but I think it's doable as long as there's 5~10 psi left and you inflate in short bursts.
Link for the user manual is here for more info: Michelin 12264 User guide
There's a higher capacity and more heavy duty model though it's already around Php2.3k++ yata:
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
