Results 1 to 10 of 21
August 22nd, 2016 03:02 PM #1
Hi tsikoters,
I need your opinion, I'm planing to change my stock mags 15 inch (185/60/R15) to 17 inch.
What is the best mags offset combination?
Where do I buy? I'm from sto Tomas batangas.
Thanks and by the way I'm planning to buy black mags as my car is black as well.
August 22nd, 2016 03:42 PM #2
August 22nd, 2016 06:47 PM #3
- May 2014
- 13
August 22nd, 2016 10:19 PM #4On offset selection, you need to know the offset of the stock wheel. From there, compensate if you are getting a wider wheel than stock (unless you are going for the look where the wheels extend beyond the fender). Please note that too extreme an offset/wheel width can lead to clearance issues or putting excessive strain on wheel bearings. Many shops sell wheels but please make sure you get a quality wheel and decent tires. Which set to go for becomes a function of budget so just do some research on that.
- Jul 2009
- 153
August 23rd, 2016 10:13 AM #5Be prepared to upgrade your suspension to compensate for the stiffness effect of low profile tires or else magsisi ka sa tagtag ng ride and eventually bumalik ka lang sa stock. Sa 16" medyo tolerable pa. Yan ang mga nabasa ko sa mga ibang threads.
August 23rd, 2016 10:33 AM #6
Check online for a tire size calculator to check wheel height and rpm differences. Your choice of new rims & tires should be less than 5% of your stock specifications. Going +2" will be fine on your stock suspension unless you drive a like a maniac of bumpy roads, humps, or potholes.
With your wheel size, the options you have would be 205/40/17 or 205/45/17. The 205/40/17 will have a similar profile as your stock rims&tires but the amount of sidewall may not be that friendly to bumps. 205/45/17 will be a bit bigger but it offers more rubber, not to mention it is a more common tire size. 215/40/17 is an alternative but the 30mm difference in tire width may cause some rubbing in the tire well.
August 23rd, 2016 11:32 AM #7
Thank you sa mga input! I'm also thinking if I will just buy the TRD mags 17 inch for Vios in Toyota san Pablo, wla naman pinagkaiba sa suspension yung TRD vios vs sa Vios E ko? please correct me if I'm wrong.
August 23rd, 2016 11:39 AM #8
August 23rd, 2016 11:57 AM #9
- Jan 2016
- 5
September 24th, 2016 04:05 PM #10
Are they on track to surpass last year's sales?
Car Sales Data (2025)
