Results 1 to 20 of 20
    Oct 2011
    My front tires are schedule for change , Choices are:
    Hankook na 2012 ang manufacturing date 2,400 each o
    Deestone na 2015 ang manufaturing dates 2K lang
    Aug 2015
    400 lang sir difference dun ka na sa bago.
    Quote Originally Posted by Aracad665 View Post
    kuha ka na lang ng iba 3 years ng stock yung hankook at yung Deestone naman questionable pa ang reliability niyan harapan pa naman ang papalitan mo. Gadjah Tunggal maganda mura pa.
    errr. parang wala akong mapisil sa choices ah.
    hankook is reputable, but old.
    deestone is unknown but new.
    i would look for something better and peg some budget at 3k.
    choices:
    a. federal
    b. kelly
    c. toyo
    d. achilles
    GT i think is at around 3.2 -3.5k each, depende sa size.
    choices:
    a. federal
    b. kelly
    c. toyo
    d. achilles
    Oct 2011
    Thanks Guys, Ok ba ang federal hindi ba ito gawang China?
    Feb 2011
    It does not matter if it is made in China or not. Iphone nga natin puro made in China. What is important is the brand reliability. For China made, I had success in using Sailun and Wanli. From the brands posted above, my vote goes to Achilles. Hardly found a bad review on it.
    Avoid the old hankooks.
    Oct 2009
    westlake,china made pero tested ko nadin.
    Mar 2015
    I wouldn't recommend goin cheap on tires as these are the only thing between your car and the road. If these fail on you accidents follow. Consider these in buying tires sir. Don't use too cheap a tire. Happy motoring!
    even premium tires have a failure rate. remember firestone? di porket mamahalin maganda na
    Mar 2015
    Quote Originally Posted by Triskelion68 View Post
    Lahat naman sir nang products have lemons and i'm not saying na yun best ang bilhin i'm just saying na don't go TOO CHEAP on tires. If you can afford a better set it's better to buy them instead of the cheaper ones. I've seen accidents because the tires blew up in star toll and it's not a pretty sight. Running fast in the heat of the day blew his front tires and turned turtle. I just want motorist to be aware that it's not just a tire. Your life depends on it.
    Aug 2013
    Get the ones with the latest manufacturing date. No older than one year from your date of purchase.
    Suggestions for cheap tires:
    1) Accelera Phi (not Phi R) - good comfort, excellent road noise, average braking, good dry grip, average wet grip
    2) Achilles 2233 - average comfort, below average road noise, average braking, excellent dry grip, below average wet grip
    3) Sailun Atrezzo ZSR - good comfort, good road noise, good braking, good dry grip, average wet grip
    All these tires have excellent tread wear and will easily last over 20,000++ km. Would honestly buy high-end models of cheaper tire brands than low-end models of more expensive tire brands. I've used low-end models such as the Bridgestone Ecopia and Falken Ziex from well known tire brands and would honestly stick with the higher-end models of certain budget brands. Kind of like buying a smartphone. The low-end Samsungs are bad, only the high-end models are good. For the price of a low or mid-range Samsung, I'd rather buy a Huawei or Sony. Cheaper and just better specs for the same price.
    ^ good point bro
    aside from the budget friendly tires mentioned previously, you can also add the likes of turkish made petlas and indonesian brands delium and neuton tires. i've heard good things about them
    ^ good point bro
    Jun 2011
    When choosing tires it is also important to check the thread wear or tW-- should be hingher than 380.. And temperature Traction should be rated A
Low Budget tires and Date of Manufacturing
