Results 1 to 20 of 21
    Hi guys,
    Ano kaya ang problem ng gulong ko, sabay sabay binili yung 4 na gulong ko and yung isa mabilis bumaba ang hangin compared dun sa 3. Nirotate ko na sha sa iba ibang position para malaman ko kung gulong ba talaga yung problema and siya lang talaga ang mabilis maubos ang hangin, bakit po kaya?
    Hindi naman sha nafa-flat, parang mabilis lang talaga bumaba like 3 days pa lang from 32 nagiging 24-25 na sha samantalang yung 3 gulong ko nasa 31 lang ganun.
    Ano po ba ang dapat kong gawin?
    Thanks in advance
    Since you rotated your tyres (rims in the same positions, right?) and it's still the same tyre, then there must be a microcrack on it. Have it thoroughly checked in a vulcanizing shop. You should be able to find what's the problem in it....
    Anyway, have the offending rim and/or tyre checked thoroughly.
    7606:mobile1:
    Sep 2008
    old school lublob-tubig habang may nakakabt na compressor ng hangin technique should do the trick.
    Na vulcanize na ba tong tire na to dati?
    baka yung patch natanggal or natuklap.
    Jan 2003
    Should be obvious na may singaw yang goma mo. ;)
    Quote Originally Posted by av427 View Post
    Hi guys,
    Thanks in advance
    pa check mo lang yung affected tire. obviously, may leak.
    Sep 2005
    Quote Originally Posted by 1D4LV View Post
    +1...sir pabagklas mo then palinis mo ung rim na kinakapitan ng goma. may matitigas na dumi kci doon maybe when they fit ung new tires mo hindi nilinis pinahiran lang ulit ng pandikit then salpak agad. ako sir out of 4 new tires 1 din ang sumabit kci dami namin namimili ng gulong sa banawe kya mabilisan ang gawa nila walan linis linis.
    Aug 2009
    exact same thing is currently happening to my westlake tires. ang bilis bumaba ng tire pressure. sent them to the vulcanizing shop but we couldnt find anything wrong with them. Will have to have it checked again.
    Hi guys,
    Thanks in advance
    sobrang nahirapan ako magisip ng sagot sa tanong mo ah....
    you should probably bring your car to a vulcanizing shop?
    easy lang shadow.
    :headache: siret. what's the answer?
    3 sources ng air leak:
    1. most obvious would be a puncture in the tire.
    2. defective air valve (pito) minsan yung pito mismo ang sira pero pwede din kasi mag leak dun sa base ng pito kung saan ito nakakabit sa mags.
    3. tire bead is not seated properly.
    most vulcanizing shops can remedy these easily. pa check mo na lang paps.
    Thanks po sa lahat ng sagot,
    Shadow, salamat sa sagot mo miski may tonong pang-asar- Sorry pero di naman ako magtatanong kung wala pa ko ginawa- pinatignan ko na yung gulong mula nong napansin ko na parang mabilis bumaba hangin, wala naman daw butas. Matagal na to, mula nang binili ko yung mga gulong ganon na sha.
    Never pa ito na-vulcanize, mahahaba pa nga ang threads nya kasi bago pa sha.
    Iniba iba ko na din yung takip nung pito (?) pero ganon pa din-
    May posibility kaya na may crack sha na di madaling makita? Pano kaya kung ako mismo ang maghanap? Pano ba ginagawa yung lubog-tubig method?
Mabilis bumaba hangin ng gulong ko
