Results 21 to 26 of 26
- Sep 2015
- 2
September 22nd, 2015 04:41 PM #21
November 18th, 2016 08:49 PM #22
ang tigas ng lug nuts ko. hindi ko kanina matanggal kasi mag rotate sana ako ng tires. any ideas how to "soften" them? i already sprayed wd40 on it's innermost end / stem hoping it would budge by tom
btw, ano ba ang recommended force para tama lang ang pag-tighten ng mga lugnuts? i just recently bought a torque wrench for this specific purpose
November 18th, 2016 09:04 PM #23
Your owners manual should have the torque figures.
If all else fails, get a long piece of pipe and use it as an extension for your tyre wrench.
(But) You may break a few bolts with this process.
Let the WD40 steep overnight, who knows.
November 18th, 2016 09:07 PM #24
100nm
Most shops have pipes to extend their tools
November 18th, 2016 09:16 PM #25
i actually used an extension pipe kanina...pero alalay ako. nakakatakot nga maptutla ng lugs although fairly simple to replace naman din. i have a pipe extender kasi dual purpose din - as an assist for times like these and pamalo na din just in case
anyhow, i hope the wd40 weaves its magic. of the 6 nuts i tackled earlier, i was able to loosen only 2 of them
November 18th, 2016 09:17 PM #26
Just saw a skinny dude standing and jumping on the lug nut wrench 😂😂😂😂 flat tire woes.
^ Ako I just use the good ole mini elm327 OBD2 scanner. Pero usually sa long drives ko Lang...
