Page 84 of 121 FirstFirst ... 347480818283848586878894 ... LastLast
Results 1,661 to 1,680 of 2415
    #1661
    "tires are not bananas", by michelin.
    interesting read.
    Jan 2019
    #1662
    Wow grabeh ang galing naman ng tire na yan. baka depende din yan sa driving style sir.
    Jan 2019
    #1663
    Mga idol, may tanong sana ako, I'm getting a new hyundai accent 1.4 GL MT next week. Tanong ko lang sana kung pwede ko agad i travel from Mindanao to Luzon which is more than 1300KM distance? 1000 ang alam kong PMS, di po kaya ito makaapekto sa performance ng car, considering na nasa break in period pa lang then ganun na kalayo ang biyahe?
    Salamat po. Pasensiya na this is my first car. Thanks
    Jan 2019
    #1664
    Thank you for this. big help
    Jan 2019
    #1665
    Quote Originally Posted by GTi View Post
    70tkms with one set of tires? How did you manage that?! [emoji33]
    I am guilty of not rotating my tires. My GT fronts on the Revo had been replaced due to wear at around 30tkms. The rears are still there, now at around 45tkms.
    Sent from my SM-G900I using Tapatalk
    Ano po logic bakit need i rotate ang tires? TIA
    Jan 2019
    #1666
    Sp00nman,
    I've been using Falken for almost 1 year, no problem.
    Kumho is also okay.
    Try going to Minerva Tyre Gallery in Macapagal for Kumho.
    I noticed you are from Batangas, there's Minerva Tyre branch sa Sta. Rosa - Tagaytay Road.
    Thanks for this one, mga bossing
    Apr 2008
    #1667
    Quote Originally Posted by nikkol View Post
    Wrong thread for this. But IMHO, 300kms overdue will not be detrimental to the car. Though you may want to have that oil change done in the nearest casa once you arrive for warranty purposes.
    Rotating tires helps avoid uneven wear.
    Jan 2019
    #1668
    Thank you po. Ganun na lang nga gagawin ko, or kung saan abutin ng 1000KM na may Hyundai na casa ipa PMS. Isa na lang sir, ayos lang po na travel ang ganun kahit bagong kuha pa kotse? May narinig lang po kasi ako dati na pag bago need pa i break in? Salamat po.
    Sent from my SM-J730G using Tapatalk
    Apr 2008
    #1669
    Well, you do need to use the car for it to "break in". [emoji16] Your owner's manual will have detailed instructions on the limitations of driving under break in period. But generally, as long as you don't flog it to its limits too much, you will be fine.
    Jan 2019
    #1670
    Thank you po...
    Jun 2009
    #1671
    Sino na dto nakasubok ng atlas tyres? ok ba gamitin ? Thanks
    Nov 2014
    #1672
    Quote Originally Posted by AkiraMidori View Post
    Hi I need suggestions pls for a staggered set
    225/45/17 at the front and 245/40/17 at the rear
    or
    215/45/17 front 235/40/17 back
    what tire brand is good ung hindi maingay? nagcanvass ako kahapon at ang mga naibigay saking brands at comforser, accelera, west lake and changseng(?) tires
    may suggestion pa po ba kayo? preferably in this price range po sana.
    ito yung gusto ko na itanong dati pa.. ganito ba palagi config nito 20 higher ang lapad then 5 lower ang kapal.
    pang kotse lang ba ito o pwede ren sa lahat, ours is Ertiga?
    paano ang spare tire?
    lagi ba sa rear ang mas malapad?
    me issue ba sa FC
    185 65 R15 yung amin
    TIA
    #1673
    Go for it bro...
    Just have it PMed when you arrive at your destination...
    Enjoy the drive!
    Jan 2018
    #1674
    Quote Originally Posted by sp00nman View Post
    me issue ba sa FC
    TIA
    Usually same lang sizing ng tires across all 4 corners unless there is a specific reason to go staggered like RWDs needing more traction at the rear wheels.
    Nov 2014
    #1675
    Quote Originally Posted by SpinCycle View Post
    Thanks, SpinCycle
    Ang concern lang dito eh kung anung size ng spare tire pag staggered unless dalawa spare
    Jan 2019
    #1676
    Go for it bro...
    Enjoy the drive!
    Thanks sir...
    Apr 2008
    #1677
    Our Granvia currently uses 195R15C Nankang NK Van CW25 8 ply tires. They were installed sometime 2017 and have now ran about 10tkms. The fronts are holding up pretty well, but I am surprised to see that the rears are wearing out even faster, and by a pretty large margin too. The van is driven without passengers on most days, and is very rarely heavily laden. Granted it is usually driven hard and is a rather torquey rear wheel drive vehicle, but this is honestly the first time I have had the rears wear out faster than the fronts in any vehicle we've had. Any thoughts?
    #1678
    Dumudulas ba lagi? Only thing I can think of is accelerated wear from wheelspin from loss of traction.
    Apr 2008
    #1679
    Hindi naman. It is not powerful enough to be smoking tires at takeoff either. [emoji28]
    #1680
    Pag madulas na compound bro kahit low torque small displacement gas engined cars kaya mag wheelspin. I've seen it on a Vios. Di maka akyat coz of lack of traction. Ayun, na coat ng gulong nya yung ramp 🙂
Low budget yet good quality tires
