Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
    i'd also like to do this.
    but my fear is that over-inflation might cause premature tire failure.
    so what i do is add 3 psi only.
    Tires have a max recommended PSI on their sidewall. This is a very conservative number cuz tires can actually still go much higher than the max PSI indicated, but if you wanna overinflate, that's a good number to start with.
    You can also inflate the tire with pure N2 so that it loses pressure slower than your usual 78% N2 air. Make sure to have a tire valve cap too.
    Jan 2016
    Doc, my recommended tire pressure is 30, but I always fill it with 35 hehe..
    Sep 2014
    You won't really need a new spare, you can keep your rotation with just 4 tires and keep the spare for the next 5 years (just replace it after that, or never drive fast if you're using the spare).
    Touring tires like the Duraplus fitted on the Ertiga usually last about 40-50,000 km. So you're still quite a long way from replacing. Since you rotate tires, I would expect that all 4 tires would all be due for replace at the same time instead of just per pair - that's what I experienced with my car since I rotate tires every 10,000 km. The rear tires were slightly thicker and were probably good for another 5,000 km but I prefer to replace all 4 at the same time.
    Oh, I don't. Well that is a relief. 3-5k din natipid ko dun.
    Sent from my ASUS_T00J using Tapatalk
    Nov 2015
    Question how long is the lifespan of tires if rarely use? In terms of years? Let say you rarely use the car. How long before you change your tires? Thanks sa sasagot.
    Quote Originally Posted by asamante View Post
    6 years. How to Know when Car Tires Need Replacing: 1 Steps
I need advice re: my tire
