Originally Posted by
voltscastillo
the 99 V has a 4wd system that relies on rotational speeds of the 4 wheels in order to activate. its not electronic, so there's very little tolerance that can be programmed in.
simply put, the differences in size bet. the front and rear must be kept to minimum so you wont F up your 4wd system. malaki ang diff bet. 205 and 225 ha... the latter is a lot wider, so more rubber and heavier. how long have you been running these sizes? do you feel/hear weird noises when you turn (thats the rear differential malfunctioning)?
i suggest you just get the same sizes na lang for whichever size you want to run. sa akin nagpalit ako ng nankang 205/70/15 dinnung 2008, all 4 less than 10k - easily cheaper than branded tyres - after having come from 225/75/r15 yoko all terrain geolandars (na sobrang bigat at ingay) which cost me about 15k all 4 in 2004.
