Results 1 to 15 of 15
    Aug 2019
    I noticed that both the front rims are hot/warm after a drive on this new car I brought last month (was released 2 weeks ago).
    Is this expected behavior?
    The front brakes are ventilated discs type. Transmission is CVT.
    The temperature, if I try to describe it, is not burning hot or "nakakapaso" hot - it's like newly-made-coffee hot. You can linger your palm/fingers there for a while. Lug nuts are also hot, but the middlemost part isn't.
    The temperature is a lot hotter than the back rims.
    mention make and model.. honda accord?
    Jun 2005
    Given the amount of friction needed to stop a car, normal na maginit yan. Mags should be warm or hotter but not nakakapaso.
    Brand new ba ang "new car" mo?
    Sent from my MI MAX 2 using Tapatalk
    Aug 2019
    Brand new sya. Honda BR-V 2020.
    we have two hondas.. i dont experience that groaning.. bring it to your dealer..have that sound checked..
    Quote Originally Posted by gomezgomez View Post
    The temperature, if I try to describe it, is not burning hot or "nakakapaso" hot - it's like newly-made-coffee hot. You can linger your palm/fingers there for a while. Lug nuts are also hot, but the middlemost part of the rims aren't.
    it's normal.
    auto books describe the heat of disk brakes as "comfortably hot".
    but i agree, "comfortable" is a big range among humans.
    it is because the disk brake pads are always lightly touching the brake rotor, generating heat whenever the wheel rotates, even as the brake pedal isn't being stepped on.
    rear drum brake pads don't touch the drum, except when the brake pedal is stepped on. drum brakes don't normally get as hot as the disks.
    to be sure, jack up the front of the car, so's the tires do not touch the ground. then rotate the wheels using your bare hand. they should rotate easily, if the brakes aren't "dragging" significantly..
    Aug 2019
    it's normal.
    I'll try this one. Salamat! Para kasing ang layo ng binyahe sa init nya haha.
    Normal lang yan. Nothing to worry about.
    May 2009
    You also posted about the groaning/ grinding sound whenever you use your brakes, right?
    It could be your front brake calipers need adjusting if they're causing a lot of friction and heat.
    If your car is still in it's break-in period of below 1000 kms. then I would observe it until the right time to take it to the dealer.
    Jul 2006
    Quote Originally Posted by sparc179 View Post
    Brake calipers either front or rear are not adjustable.
    Dec 2009
    Front wheel drive ba ang auto mo?
    If it is front wheel drive then that should be the case
    Energy generated by the engine is transferred to the front wheels that's why both front wheels are doing the grind
    Jan 2009
    It's normal.
    Disc brakes are very efficient at its job (which is to apply friction to convert kinetic energy to heat). Also, the front axle provides 60-75% of the vehicle's stopping power. It's also the reason why the front brakes are typically larger than the rear brakes and in many vehicles, the rear axles are relegated to having drum brakes as a means to save on cost.
    The warmth you feel can also be exacerbated due to heat transfer from the engine. However, heat from the engine is not that quite significant compared to the heat produced by the brakes.
    Aug 2019
    Yup front wheel drive po sya.
    From what I've seen here and from a couple of fb groups, it's nothing to worry about, pero ipapacheck ko na din come 1K PMS for peace of mind.
    Dec 2009
    ^Padagdagan mo ng grasa yung wheel bearing baka kulang ang nailagay
    Mas madami inikot ng gulong mo kesa sa tinapak mo sa preno..hindi ba?
    di ba sya sealed bro?
Front rims are warm/hot
