Results 1 to 10 of 62
- Feb 2012
- 27
August 6th, 2017 01:10 PM #1Hi
Just want to ask your opinions on these 3 brands. Any actual experiences?
I know GT is a good brand.
How about Achilles or Delium?
All these are Indonesian tires based from research but I rarely see reviews for them.
Looking to replace Stock Tires from 205 70 R15 to 215 70 R15 or 225 70 R15
Thanks in advance
August 6th, 2017 02:19 PM #2
Have tried Achilles 2233 - they lasted long as road tires considering I drive long distances with lots of corners and poorly-paved roads. I got 42,000 km before I replaced my set.
If you're not picky, these are good enough for daily drives. I got them for 3.3k per piece (225/40R18 size).
- Feb 2012
- 27
- Sep 2011
- 48
November 27th, 2017 11:22 AM #4
November 27th, 2017 11:24 AM #5
- May 2007
- 3
November 27th, 2017 11:35 AM #6Achilles is ok. Good grip in dry and wet and also tahimik. I got the 2233 passenger tire. good value for money but i had two tires worn prematurely. pero dahil siguro nawala sa alignment yung tires ko because of suspension problems
August 6th, 2017 04:36 PM #7
You can add neuton in the indon tire mix that you listed down. It's slightly more expensive than the achilles but a few hundred pesos cheaper than the GTs. I've been using a set for more than 2 years now.
The nt5000s i've got are grippy and the road noise they produce are several decibels lower than the stock bridgestone turanzas the car came with ( and its subsequent same brand, same type replacements). So far i'm a happy camper
when you look into the abyss, the abyss looks into youLast edited by baludoy; August 6th, 2017 at 04:38 PM.
- Feb 2012
- 27
August 6th, 2017 04:54 PM #8
August 7th, 2017 07:52 PM #9
Have used GT radial 31x10.5r15 on my pajero. Got it at 6k each.. I installed last
August 2011 and I already run around 70000kms on set of four. Still got 20%
threadlife as of today.. Im still using it till now. No any signs of cracks and have not experienced any flats or side bukol. A really bang for the buck,
On the other hand, I had delium tires 235/70r15 on my crosswind. I would say they are hard rubber but offers less grip. Everytime I do hard breaking, I always hears skid screeches especially vehicle is not loaded. Dangerous imho.
I cannot say about achilles, no experince on this brand.
A new BYD has arrived: Sealion 5 DM-i launches in PH with P1.198-M introductory price | TopGear PH...
BYD Sealion 05 DM-i
