Results 1 to 10 of 13
- Jun 2007
- 61
June 21st, 2007 02:37 PM #1Tanong ko lang kung anong mas ok na tires. 50 series ba o 55 seires?
Hindi ba matagtag kung 50 series?
Civic 97 po auto ko.
Tsaka kung SIR mags or Volk racing mags?
Salamat!
- 10,620
June 21st, 2007 02:53 PM #2general knowledge tells us that the higher the "series" or the aspect ratio the better the sidewall will play.
also check the width of the tire because the aspect ratio or the "series" depends on it
eg. 255/50/15
255= width in mm
50= 50% of 255= 112.5mm
15= rim sizeLast edited by kimpOy; June 21st, 2007 at 03:06 PM.
June 21st, 2007 05:10 PM #3
go with 195/55/15
better comfort and thicker sidewalls to protect you from bingkong.
- Jun 2007
- 61
June 21st, 2007 08:14 PM #4salamat sa reply.. so 55 mas ok na 15 inch na mags for comfort.
205/55/15 yung kasamang gulong.. pero undecided pa rin ako kung SIR mags o volks racing. Magdadagdag ako ng 12500 kung volks racing pero pag SIR mags e plus 6500 lang with free polish na yung mags. Ano kaya mas ok na deal?
June 22nd, 2007 08:26 AM #5
i am currently using a 55 on 15 tires. ok sya. gaya ng sabi ni miko, more comfortable and more protection sa mags.
on your last question, syempre, mas maganda volks racing.
- 10,620
June 22nd, 2007 08:35 AM #6but if you are like me who likes a stock look go with the SiR mags...
6K is still 6K
- Jun 2007
- 61
June 22nd, 2007 08:44 PM #7I went with the SIR mags and 195/55/15 na Yokohama (70-75% tires)... mas maganda tignan kaysa volks racing... 6T lang add ko pero trade in stock vti mags with 70% tires.
Sarap pag masdan ng auto.. hehe. Salamat sa advice!
June 23rd, 2007 02:03 AM #8
If your new Rim is 5.5in.- 7.5 in. Rim Width Range use 205/50/15.
If your new Rim is 5.5in.- 7.0 in. Rim Width Range use 195/55/15.
If your Rim is wider than stated inches above use 215 on wheel width.
- Feb 2010
- 33
February 18th, 2010 11:43 PM #9sir wat po mas bgay n mags para s auto k vti 99model? sir mags or spoon mags 15 inch? and wat tire po bgy n size?
- Feb 2010
- 33
February 18th, 2010 11:49 PM #10sir wat po mas bgay n mags para s auto k vti 99model? sir mags or spoon mags 15 inch? and wat tire po bgy n size?
