Results 1 to 10 of 12
- Apr 2009
- 26
February 20th, 2011 09:27 PM #1Best Tire for my 2006 Honda City? Size would be 185-55-R15. Will be buying a pair next weekend.
Currently considering 2 options:
1. Yokohama C Drive * 3700
2. Bridgestone Potenza RE030 * 4000
What would you recommend. I am not considering Goodyear Assurance anymore because of some bad experience. Also cannot buy because of unavailability here in Pampanga.
February 20th, 2011 09:53 PM #2
- Apr 2009
- 26
February 21st, 2011 09:22 AM #3Cost is not an issue. Just need a reliable set for daily driving. Factors are they should add comfort, should be silent and should last longer, and not prone to bukol or any usual defects.
One of my 6 mos. old goodyear assurance tire ay nagkagasgas sa loob dahil ni-running-flat ko daw according to a technician. I did not really run it totally flat, just under-inflated. When I got to the tire center, it still has 15psi. It was losing air due to a nail.
So would the 300 additional cost for Potenza worth it?
- 19
February 26th, 2011 07:54 PM #5
Try mo tumingin ng neuton at maxxis tires, maganda ang review ng 2 brands na un. Potenza para sa kin e pangkarera lang, don't expect na matagal mapudpod ang potenza, high performance tire ang category nyan, pumili ka ng touring type. 1 pang ok e ung bridgestone my01. madami ka mapagpipilian. Pero ang marrecommend ko e un maxxis z4s victra, puro positive ang review.
February 26th, 2011 08:15 PM #6
If there are michelin, they are also good. But between the 2 you afre referring to, much better to use Bridgestone. They are very reliable and durable.
- Mar 2009
- 35
March 1st, 2011 02:07 AM #7Avoid purchasing Goodyear Assurance tires. I bought a set of four in January this year. Just after a month, the sipes or slits where the waffle blade system (as they call it) are located, opened up. I already went to the distributor (Hi Performance Alabang) and had just the two front tires replaced, due to budget constraints. I just learned that Goodyear has this policy of replacing defective tires, but you have to pay them depending on how much wear the used tires have incurred.
Bridgestone, Michelin, and Dunlop are better brands.
March 1st, 2011 02:14 AM #8
if ok lang ang cost, get pirelli tires... I wouldn't get goodyear again..
March 2nd, 2011 08:39 AM #9
- Sep 2006
- 112
March 4th, 2011 12:57 AM #10Ok din michelin pilot preceda around 3.9k each. You can upgrade to 195-55-15
We previously supported Tapatalk for Google Play and iOS store, but both are unsupported right now....
tapatalk smart phone application.
