Results 1 to 5 of 5
- Dec 2009
- 27
March 23rd, 2013 09:08 PM #1I just want to ask for your opinion guys medyo desperate na ko sa oto ko kaya ako bumili ng kia para tipid sa gas pero bakit ganun ang lakas?
Bought a kia Cd5 some few months ago eto specs nya:
B3 engine 1300
80 amps alternator (kailangan itaas ng konti menor)
Power Steering
134a aircon compressor
13 inch mags
Free flow muffler ( exhaust ko maitim sa carbon na parang medyo oily )
Mga pinalitan at pinagawa ko dahil duda nga ako bakit lakas sa gas:
Palit Spark Plugs (pinacheck ko din ang sunog ng plugs sa mechanic ko maganda daw)
overhaul carb (change jets primary 95 secondary 120)
Change high tension wires, fuel filters, fuel float
check valve clearance, timing, all is ok
check for gas leaks may nakita ako pero maliit lang naayos na
Nagpa full tank ako after maayos lahat tinakbo ko ng 14 kms. then full tank again pero 135 pesos ang nadagdag so compute ako 5kms/liter lang tsk tsk help naman mga guys
BANNED BANNED BANNED
- Mar 2013
- 73
March 25th, 2013 02:37 AM #2
- Oct 2009
- 2,271
March 25th, 2013 04:24 PM #3malakas nga yan dapat manlang 10km manlang,,
April 5th, 2013 08:56 PM #4
dapat nasa 12-14km/l ka sa hiway. city drive nyan is around 10km/l. paki check baka may vacuum leak lang.
- May 2014
- 2
May 22nd, 2014 07:19 PM #5Hi mga sir- newly acquired Kia CD5 96model.. so far ito palang ang mga napagawa ko- Tune up, changed sparkplug, replace Aux fan for aircon,, replace bypass radiator hose, replace wiper motor, replace gasket, and so far may leak sa isang bypass hose sa bandang ilalim [ero nagawan na ng paraan by putting steel epoxy since tubo naman sya pero now wala ng leak, im using valvoline coolant muna.,edyo magastos at first pero given naman kasi 2nd hand na ito. napansin ko lang medyo malakas ang gas consumption, pinacheck ko sa customers cradle sa shell laspinas, mataas daw idle so binabaan ng kunti , now under observation ko sya. nagundercoat ddin ako para iwas kalawang. so far hindi ko pa sya nappa change oil kasi ok pa naman daw ang oil at yung fuel filter hindi pa napapalitan pero baka ito na ang isunod ko. share ko lang po itong experience ko sa cd5 since first time ako nagkaroon...hindi pa naman sumasakit ang ulo ko pero bahagyang nagkakabutas na ang bulsa ko.... sa halagang 55k ko nakuha ang Kia, ang linis din ng interior at walang issue naman sa engine except yung mga nasabi ko na.
Choosing one would depend on your driving and parking conditions. Do you have your own garage =...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
