Results 1 to 10 of 14
April 17th, 2010 09:33 PM #1
share ko lang,
baka naexperience niyo din to..
ano kaya naging probLEMA??
kakatapos ko lang icarwash si pregio..habang nagtutuyo ako pagsarado ko sliding door ang weird biglang!
lock! unlock! ang door lock walang tigil!!!
ginawa ko sinusi ko para buksan lahat ng pinto at pati yun di hila sa likod biniksan ko na wala pa din nangyari wala pa din tigil ang lock unlock
naisip kong tanggalin negative ng battery terminal
ayun tumigil... pero pagkabit ko uli ng negative ayos at wala na ang nagluluko na door lock
pero chineck ko ang automatic doorlock ko wala na..
para na siyang manual na isa isa mo na siyang bubuksan
ano kaya nangyari?? nag iisa pa naman ako dito sa bahay hehehe
share niyo naman baka nangyari nasa inyo to
mga ka pregio help!!
TIA!
April 17th, 2010 09:40 PM #2
Obviously the power lock mechanism got wet and the water was shorting it. This caused it to cycle lock-unlock. You have to dry the door lock mechanism before plugging it back
April 17th, 2010 09:56 PM #3Obviously the power lock mechanism got wet and the water was shorting it. This caused it to cycle lock-unlock. You have to dry the door lock mechanism before plugging it back
i'll try tomorrow...
April 17th, 2010 10:30 PM #5
- Oct 2009
- 95
April 18th, 2010 12:24 PM #7sigurado dahil nga yan sa may nagground sa line ng powerdoor mo, check mo na agad line para makita mo yung grounded, baka abutin ka ng tag-ulan at nag iisa ka sa liblib na lugar tapos bigla umulan,, nag lock-unlock pinto mo,,ano kaya gagawin mo???hahha... awooooooooooooo
- Jun 2004
- 290
April 19th, 2010 07:59 PM #8bro had the same experience with my pregio. it was like the door locks were possessed. worst thing was that i would lock it when i park it in the parking of a mall. and it would find it unlocked when i got back.
so i brought it to my trusted electrician in cubao. and he simply replaced the central lock module with a replacement one (Taiwan). then everything was back to normal.
April 19th, 2010 08:15 PM #10
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
