Results 1 to 7 of 7
    Sep 2010
    Hello mga bro!May problema ako sa engine temperature kasi tumataas kahit both condenser fan at radiator fan are running.Water level sa radiator at reservoir are normal too.Nakapagtataka kasi pag ang car is in motion the temperature decreases below half on its indicator and seems normal but when the car is on stop or during traffic the temperature rises again 80% .Pls. help me with this one.thanks mga bro!
    Radiator Cap kaya may sira nito?
    Not enough pressure, hence nagboboil yun tubig.
    Sep 2010
    ok, bro echeck ko lang if nag boboil ba yung tubig kasi bago rin ang radiator cap.
    Aug 2004
    Sounds like the fans are not running fast enough. Better have the voltages checked.
    Could be any number of other things, but I'd check those first.
    Sep 2010
    ok,bro thanks! e-check ko ang supply voltage nang fan.
    kindly check radiator fan upon turning off your engine. if it rotates after turning off your engine, silicon oil is badly needed. dapat matigas ikutin ang fan kapag turned off ang makina.
    Feb 2010
    I had a similar problem with my 01 Carnival...it turned out to be a stuck-up thermostat. Prior to that...a faulty rad fan. Hope it helps.
2003 kia sedona carnival V6 rad.cooling temp.problem
