Guys, ask ko lang po sana kung sino sa inyo ang nag-install ng boost gauge para Isuzu Dmax.. Balak ko po kasing kabitan ang Dmax namin... Thanks sa reply...
madali lang yan bro, it follows the same basic principles for all turboed cars naman :D
usually pwede mo siya itap dun sa isa sa mga small hoses leading from the turbo outlet.
i think may thread dito sa tsikot about tapping into that line to hook up a boost gauge.
or if you can't find it, i'll try to post pics on how i did mine, pero sa pajero.
just inform us on this. :D
if malapit ka pa from me i could probably meet up with you and assist :D
medyo malayo ako sa inyo mga sir.. dito pa po ako sa baguio. ano po bang gagalawin sa engine pag kakabitan ng turbo gauge?
ahehehehe malayo nga.
hmmm. actually, once you attach the boost gauge, you don't need to tinker with anything sa engine, since the gauge is only there to give you an indicator of how much air in psi or bars (depende sa unit na binili mo) the turbo is pumping out.
sige sir, post pictures and details like what brand of gauge did you use. try mo rin ang photobucket (http://photobucket.com/) to post your pictures. Gawin mo lang public (not private yata) para maview namin.
too bad my cousin who has a dmax is in laguna.
anyone in the QC area with a dmax we could use for photoshoot opportunities? kahit just to show lang where to tap, etc?
would this help? I think I should've taken a pic on the other side hehe![]()
grayfuz,
may binebenta akong boost controller and gauge, if you are interested...i also know someone who can attach the same. in baguio.
PM me for details
ei guys gusto ko lang sana malaman kung may performance gain ba pag naglagay ka ng boost controller sa dmax? kasi dati balak ko din sana mag lagay kaya lang sabi ng isang shop sakin wala din kuenta kasi ma aad ko lang daw na boost is .01bar lang daw kasi d na daw kakayanin ng stock turbo eh so parang useless din daw totoo ba o ma boboost ko pa ng mas mataas...kaya turbo timer nalang nilagay ko..
cardo: hmmm...meron pa kaya more detailed pics like sa kaloob-looban ng engine bay? try to follow that intake tubing, it should lead you right to the area where the turbo is. could you get a closeup on that area? :D
regarding boost controllers, ok naman siya actually, yun lang, some makes seem allergic to it (like the subaru impreza WRX) because the boost controller as much as possible delays the opening or full opening ng wastegate until it reaches a set pressure, just like the washer method would. yun nga lang, you should know din how much boost your engine on stock internals could take.
oh yeah...may point din ang turbo na it loses efficiency when you try to make it pump out more psi than normal.
Read an article on HotRod Mag about this...the higher pressure will also make the air hot (tama ba sa physics recollection ko na directly proportional ang temp sa pressure - increase the pressure, the temp will also increase) kaya mas dense tuloy ang oxygen content nito....so hindi hahatak ng tama as expected.Originally Posted by nugundam93
You need to know more about your engine...dyno test it if needed...when you adjust the manual boost controller, the pressure gauge will help out determine right pressure with the right power produced.
yes bro ... higher pressure galing turbo = hotter air. kaya po merong intercooler sa harap to 'cool-down' the hot-air from turbo bago pumasok sa engine.Originally Posted by wildthing
pero hotter air is less dense than cold air. yng pagiging less dense ng hot air ang nagpapahina ng hatak ng makina.
dyno test? for me hindi na kailangan (magastos kc)... just look for a safe, clear straight road, time your ride from 0 to 60 kph and 0 to 100 kph before changing any components in your engine... tapos after mo i-upgrade or fine-tune yng parts, do the drag test again.
