Originally posted by garyq rpm related ang any turbo. Sa atin around 2-2500 rpm nagsisimula ang boost.
Does that mean na pagkakaandar ng ride ay pwede kagad patayin yung makina(ex; dadaan ako ng malapit banko before going to my destination). Pwedeng di ko na pahinga yung turbo ng around 2 minutes.TIA
Nap: Oo sa manual yan. Looks like the 720 is from cold idle, kaka-start lang. Bok, thanks for the added info.
edwin: May turbo timer ako and a spare key. Pag malayo yung biyahe, cool down ko 2 minutes. Pag withdraw lang sa ATM and I can see the car di ko na pinapatay. I lock it with my spare key
boknoy: I think one has to see the basics of how a turbo works para maliwanagan dito. The turbine is moved by the exhaust gas coming from the engine. This in return is connected to a compressor wheel (more like a centrifugal pump) that "compresses" the air into the cylinder so that more air means more fuel you can inject producing more power. It takes a certain amount of exhaust gas to turn the turbine (because of inertia) kaya may turbo lag. The turbo syst has to overcome this so that the compressor on the other side of the shaft spins faster and compacts just enough air to the cylinder to give you the additional power. Pansin ko lang sa 4JG2 around 2000 rpm yung start ng noticeable boost and around 3200 rpm yung optimum. This is the reason kaya yun ang nasabi ko. Based lang yun sa rig ko. Hope this helps
boknoy: loko mo ko ha bro sino ba pwede makausap tungkol sa tranny ng ubs69? Yung sa local GM ba yung tranny or Aisin-Warner? Nga pala ano ang konsumo nung local na 4JG2 na matic tranny? May matic ba na lumabas? Thanks!
