Results 1 to 3 of 3
    Feb 2011
    everytime na iturn ko yung steering wheel may maingay na tunog, mas rinig pag naka idle lang yung oto tapos tinurn mo. dati naman wala..
    is it the pump? ..or kailangan lang ng power steering fluid?
    Thanks.
    Feb 2011
    may nabasa ako sa isang thread busted daw yung ung center post at idler arm..
    could it be?
    Feb 2005
    Quote Originally Posted by khem09 View Post
    Thanks.
    1st things first, have you checked the power steering fluid level if it's still at MAX level? (but should not be over MAX) If the level is below MAX --- moreover below MIN, then add fluid until MAX level and test. If all things fail, then check the pump.
Steering Help.
