Results 1 to 14 of 14
    Apr 2004
    How does this new setup improve the suspension performance of the New Isuzu Crosswind? Would it be possible to replicate on other AUVs?
    Shocks look stock... Could possibly be different rating/thickness on the leaf spring layers.
    same with 2005 dmax, naka flexiride na din
    Nilipat nila yung shock mounting ng isa sa bandang harap ng diff. Pwede rin naman gawin ito sa trusty welding shop. But you'll need to be sure there's an existing crossmember to weld on.
    Probably the leaf springs had different spring rate and all add up to marketing hype.
    pag sinisilip ko ilalim ng 2004 crosswind, halos parehos lang sya sa revo.. yung the way na nakapwesto yung shock absorber (bias mounted) is the same as the revo..
    probably yung spring rate lang ng leaf springs ang nabago sa sportivo..
    pero let's wait for other crosswind owners here
    The shox are installed in such a way to prevent axle wrap. Typically this setup is use with leaf springs suspension.
    Dec 2004
    mga pre, malakas kutob ko na gaganda ride if lagyan ng OME gas shocks. puede kaya?
    repoman-yes crosswinds can be installed with OME shocks
    Jan 2003
    I dont see anything different from the pix itself. Siguro yung reversed spring setup. usually AUVs have standard leaf springs.
    Dec 2004
    tnx ARB for confirming. i have OME on my strada 2000 suliiiiiiit! pag ilagay yan sa sportivo malakas kutob ko nakangiti driver at hindi pagod
    Jan 2003
    repoman875 , pasakay naman! para malaman ko kung ayos na ayos! :D
    para sa akin mas malambot na ang ride ng crosswind kesa sa old hilander series. this was before the upgraded suspension setup.
    Is there an OEM for REVO? Do you think it will improve the ride? Advise please.
    OEM for Revo will always be available at your suking casa or Toyota authorized supply store. :D
Sportivo Rear Suspension Improvement
