Results 1 to 4 of 4
- Feb 2013
- 3
February 20th, 2013 02:21 AM #1mga sir tulong naman! ang kotse ko isuzu crosswind xto a/t 2002. problem mga sir yung speedometer ko sa umpisa gumagana pero pagtagal hindi na, nasa 0kph na lang kahit umaandar yung kotse, minsan kapag nakahinto yung kotse yung speedometer nag-indicate ng 160kph minsan 180kph kaya kapag aabante na akala ng transmission nasa high speed ako ilalagay niya yung high speed gear kaya namamatay yung makina. pinalitan ko na yung speed sensor at speed gear pati yung speed driven gear sa casa pero ganun pa rin ang problem. blinking din ang check trans ko. please help anybody. thanks a lot!!!
February 22nd, 2013 02:30 PM #2
- Jan 2009
- 163
February 26th, 2013 12:37 PM #3pacheck mo yung cluster gauge sa ibabaw sir baka un ang may diperensya meron gumagawa nyan nagcacalibrate .... then if ok naman yung nabanggit mo sa speed sensor at gear driven check mo ung electrical nia anything na magloose magiging cause ng check transmission light. mejo mahal pala sa casa pag gauge but meron nakukunan nyan na surplus mas mura...if smooth ang lipat ng gear wala problema sa tranny mo mostly sa connection or electrical ang may problema. just my 2 cents nangyari sa akin yan check engine light ang cause yung speedometer gear driven napudpod then pinalitan ko kasama ung bakal sa loob yung speed drive ok na uli.
- Feb 2013
- 3
February 26th, 2013 05:26 PM #4Thanks po NELANY at OTIL,FLORES sa suggestions ipapa-check ko po next week, will update you po.
Couldn't have explained it better myself. This was the point I was making. They (either manually or...
SC (temporarily) stops NCAP
