Results 1 to 6 of 6
    Apr 2009
    Hello mga gurus tanung ko lang napapansin ko kasi while shifting to 1st gear & 2nd gear parang hirap ipasok yung kambyo tapos yung clutch ko may lumalangitngit na tunog pag inaapakan and medyo matigas ano kaya ang problem?
    Jun 2008
    Quote Originally Posted by sanik View Post
    Di kaya dapat na palitan ang pressure plate & release bearing nyan.
    But before that.. Bleed mo muna ang hydraulic side ng clutch mo baka air bound lang kaya kulang sa depressed ang pressure plate pag tinapakan ang pedal. Pag di nakuha sa "bleeding" then you have no choice but to have the clutch overhauled
    Apr 2006
    Quote Originally Posted by weisshorn View Post
    Tama si sir, pero may isa pang solution baka umubra, try mo rin e adjust ung clutch pedal mo ng paunti unti, pag adjust sikipan mo ung lock na knot tapos try mo ipasok sa first gear at reverse, obserbahan mo kung may sabit pa rin, pag talagang di umubra, no choice ka sir overhaul ng transmission na talaga last resort mo nyan
    Apr 2009
    Quote Originally Posted by tabuso286 View Post
    Sir tabs yung clutch pedal ko na paadjust ko na last year pero ganun parin walang pagbabago and also di pa ako nakapag papalit ng transmission oil at gear oil magkano kaya yung pressure plate,release bearing & clutch disc?
    Apr 2006
    Di ko na ma recall sir mga prices ng parts, 2006 pa kasi ung huling overhaul ng transmission ko eh; ang natandaan ko lang nasa 7-8k ginastos ko kasama na ung 1.5k na labor
    Apr 2009
    Napansin ko rin when shifting to 1st gear tapos hindi pa irerelease yung clutch mababa ang idle ng engine ko.
Isuzu Hi-Lander Xtrm Clutch Problem
