Results 1 to 6 of 6
February 24th, 2011 07:46 PM #1
Hello mga gurus tanung ko lang napapansin ko kasi while shifting to 1st gear & 2nd gear parang hirap ipasok yung kambyo tapos yung clutch ko may lumalangitngit na tunog pag inaapakan and medyo matigas ano kaya ang problem?
- Jun 2008
- 1,741
February 24th, 2011 09:17 PM #2Di kaya dapat na palitan ang pressure plate & release bearing nyan.
But before that.. Bleed mo muna ang hydraulic side ng clutch mo baka air bound lang kaya kulang sa depressed ang pressure plate pag tinapakan ang pedal. Pag di nakuha sa "bleeding" then you have no choice but to have the clutch overhauled
February 24th, 2011 09:42 PM #3
Tama si sir, pero may isa pang solution baka umubra, try mo rin e adjust ung clutch pedal mo ng paunti unti, pag adjust sikipan mo ung lock na knot tapos try mo ipasok sa first gear at reverse, obserbahan mo kung may sabit pa rin, pag talagang di umubra, no choice ka sir overhaul ng transmission na talaga last resort mo nyan
February 25th, 2011 12:05 AM #5
February 25th, 2011 11:53 PM #6
Mazda 3 is incredibly tempting, unfortunately the hybrid is not included in the coding exemption...
All New Toyota Corolla Cross
