Results 1 to 11 of 11
    Jan 2010
    What is the recommended tire pressure for a 2002 Crosswind XUVi?
    30 psi
    34-36 psi kung tipid mode but expect a harsher ride. but it will be minimal since it has higher ground clearance than a regular car.
    Parang ang lambot naman yata ng 30PSi para sa laki ng gulong ng Crosswind. Mga 32-34 siguro, pwede ... yung 35 - 36, yun yung mas matigas ride.
    Feb 2005
    Hope this helps.
    Jan 2010
    Thank you guyz for your instant replies. Right now the tire pressure of my Crosswind is 32 PSI for the front and back tires. Will this affect my ride?
    Feb 2005
    Quote Originally Posted by nemesis041465 View Post
    It should. More air from recommended means more "bumpy". I suggest that you reduce the front to 30psi and make your rear 34psi.
    Feb 2010
    benz is right.. it should be 30 in front and 34 in rear, kasi pag-uminit mag-eexpand pa yung mga tires..ganyan pressure ng mga gulong ko sa x-wind ko..
    Quote Originally Posted by xuv2010 View Post
    no offense po ah sir, correct ko lang po.
    yung air inside the tire ang mag-eexpand, hindi po yung gulong. so, meaning, the air pressure will rise if the tires are being used at speeds. the friction and compression causes the heat. tama po ba mga bossing?
    Jun 2009
    expand din malamang ang tire kung nag-expand ang air sa loob
Recommended Tire Pressure for 2002 Crosswind XUVi
