Results 1 to 8 of 8
- Aug 2010
- 36
August 24th, 2012 08:41 AM #1hi, isuzu gurus. tanong lang po re my sportivo A/T 2007:
1. nawala yung O/D off light ko even when O/D is turned off, then napansin ko habang rekta sa NLEX mukhang hindi gumagana yung O/D, so i'm pretty sure hindi lang electrical. ano po kaya problema?
2. while moving and usually when stepping on the brakes, biglang nagbubukas or nagpipilit magbukas yung auto locks. any idea what's wrong?
And will appreciate po any suggestions kung saan pwede dalhin para mapatingnan. Thanks much.
August 24th, 2012 03:01 PM #2
1. baka yung OD sensor.
2. electrical yan.... dun sa central locking system mo.
- Aug 2010
- 36
August 24th, 2012 04:39 PM #3
- Jul 2012
- 56
August 28th, 2012 09:10 PM #4goodevening makasingit lang sa question #1: baka naman busted yun bulb ng O/D off sa panel. try to consult from car electrician. And what do you mean ang hindi gumagana yun O/D? O/D always ON yan as you are on driving unless kung i-press mo yun push button sa shift lever then the O/D off is active as you will notice coz it is luminated. AFAIK kahit busted yun bulb ng O/D off is still okay as long yun behaviour run ng car mo is mapi_feel mo na mag downshift sa 3rd gear from 4th gear in D. and thats the time you can overtake a certain vehicle as if you want.
- Sep 2012
- 26
- Jul 2012
- 56
September 11th, 2012 12:41 AM #6usually O/D switch off is using for overtaking. when you're about to overtake a certain vehicle just switch the O/D off while on the D shift and then add acceleration it will automatically shift into 3rd gear as you will feel or noticed then as you overtake then back to O/D on.
- Jun 2006
- 1,139
September 11th, 2012 01:37 AM #7At 80kph above o/d off, the rpm does not drop to near idling when you release the throttle.
- Aug 2010
- 36
September 17th, 2012 08:08 AM #8
Boy, am I glad I never bought an Ecosport!
BYD Philippines
