hi fellow isuzu owners,
Need your expert advice and opinions.
paano ba maintenance ng power steering? how frequent ang pag change ng ATF ? and ano dapat gamiting oil and how many liters?
thank you
thank you
Use ATF fluid on recommended Isuzu manual and the interval of changing ATF . Check also your power steering hose for leak .
replace every 20,000kms or 1 year.... whichever comes first.... meron naman power steering oil tLaga... from STP or yun CASITE na brand... just drain the reservoir and replace, it would take about 300ml to fill... dont use ATF fluid dahil matapang eto and tends to shorten the life of your hoses... madali magcrack, magleak, etc... ATF is being put on manuals dahil its widely readily available... or meron sa honda casas na power steering fluid talaga...
kc ATf fluids tends to get "acidic" or matapang kung tatagal... specialy when temp varies inside the engine bay...
