Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
    #21
    di na ba pwede i-straight kung baluktot? kung yung lower part ang baluktot, pano ko i-straight yun kung ayaw ng lumabas?
    Signature
    #22
    hmmm...have someone turn the radio on. I-assist mo yung antenna when going up para ma fully extend sya. Pre di ko nakikita yang unit mo pero konting adjustment lang yan. Slight lang ang pagkakabaluktot nyan. Tiyaga lang at ingat para maayos yan.
    Aug 2008
    #23
    Pwede ba ang surplus power antenna taken from RHD units install sa Orig LHD unit?
    Thank you!
    Apr 2008
    #24
    May isang beses nangyari iyan sa amin. Ayaw pumasok ng todo. Ang ginawa pinakita at pinalitan ang antenna (ung stalk mismo) ng isang 2nd hand.
    #25
    mas matindi ang akin! hindi na bumababa..
    nasunog na ata yung motor ng antenna eh...
    #26
    Power antenna for trooper is around five thousand plus. But if your motor is ok, you can buy the antenna itself with the plastic chord inside at 1800. I did it my self, just have to be patient and cool headed when doing it. Rememe\ber to remove the unneeded teeths if not it will lock.
    #27
    4JGt, sa CASA ba yan o sa banawe palang yang price?
    #28
    Walco at 7110277, 7110299 look for Melchor or Dennis. Its much cheaper than buying the whole assembly. Tyaga lang para kasing spring yung plastic, mapalag.
    #29
    thanks thanks.. siguro bibili nalang ako sa walco tapos sa iba ko nalang pa install..
    #30
    kelan? sabay tayo
    nagloloko parin narin sakin last week lang.
    bad thing is kahit binunot muna yung susi sa ignition umaandar parin yung motor :puyat:
    pag inalalayan ok naman yung sakin (pababa)
    hindi naman fully extend pag pataas
    #31
    yung akin naman natuluyang nasira dahil nag stuck na yung loob.. ayaw na tumigil nung motor sa kaka andar kaya nasunog na siguro yung motor..
    hindi ko pa alam kung kelan ako pagawa.. baka matagal pa
power antenna for trooper
