Results 1 to 10 of 16
March 19th, 2006 06:08 PM #1
1 gal shell diesel super
1 vic 208-A fuel filter
1 vic 512 oil filter
top 1 high temp greese
prestone fluid
1 lit shell ATF
change oil, replaced ATF, repack front bearing left/right, adjust valve clearance, clean brake system and check ( need 6k after 4 months kailangan ko mg palit ng brake pad front )
thanks rgie murang PMS sa sunod ulit..............
March 20th, 2006 06:12 PM #2Originally Posted by x-wind
sana nakunan mo ng picture yung repacking para merong educational feature tayo on wheel bearing repacking :D
tanong lang..pano dinadrain yung brake fluid sa clutch fluid reservoir? yung sa brake fluid nakakalas ko, yung sa clutch, parang ayaw matanggal eh kahit niluwagan ko na yung parang clamp sa ibaba.
March 20th, 2006 09:59 PM #3
*rsnald -- the last time i had mine drained...they just used a syringe. i don't know that's the way to do it though...pero na drain naman sha eh.hehe
March 20th, 2006 10:07 PM #4
usually siphon lang talaga pag drain ng brake/clutch fluid sa reservoir...
March 20th, 2006 10:21 PM #5Originally Posted by rsnald
re brake fluid sa clutch di talaga natatangal yun service boy natin used basahan to drain and clean.
pic hahanapic ko yun file ko for repacking
March 20th, 2006 10:43 PM #7Originally Posted by theveed
shell lang gamit ng xwind ko from start from fuel, oil, gear oil,atf model po kasi ng shell xwind ko :bwahaha:
March 21st, 2006 10:00 AM #8Originally Posted by x-wind
re: front brake pads, P5000+ yung kuha ko last year from isuzu pasig. rear brake shoes P6500+. Adjust for VAT increase maybe yun na price nyan. of course may bendix replacements naman w/c are cheaper.
March 21st, 2006 10:34 AM #9
bendix brake pads meron sa jayson's (binondo). P1k set sa front and P1k set sa rear. para sa trooper/bighorn pala ito. i'm sure meron din sila for crosswind.
March 21st, 2006 10:41 AM #10
near 20k pa lang xto ko kaya transmission and differential oil, front bearing repacking, oil/filter change, clean air filter lang muna this coming holy week break.
in my opinion, the more effective deterrent against car theft, is the visible deterrent. if the...
