Results 1 to 5 of 5
    Jun 2005
    Tanong ko lang mga gurus... I have seen oil in my radiator last month. my ride is hilander '00, and i pinagawa ko na, top overhaul pinalitan ng cylinder head gasket,,, but note that hindi naman nag ooverheat ang radiator ko...then nawala naman pagkapalit,, then after a month again i notice oil in my radiator... is there anyone who had encounter this same problem... sabi dun sa kotse.com with similar problem is the "oil cooler" daw....
    need your opinion mga sir...
    TIA.
    Sir nag pa re torque na ba kayo ng head? Kailangan kasi pa retighten after a while para lalong mag press ang gasket between the head and block. Na leak test ba yung cylinder head ninyo? Pina reface niya bva sa machine shop?
    Jun 2005
    Quote Originally Posted by 4JGtootsie
    hindi pa sir, pero pinatingnan ko na ang oil cooler, pinatay muna at dinerekta na ang water s radiator agad, hindi na daan sa cooler... under observation pa... pero nawala na din ung oil sa radiator this past 3 days...
    san ba nag papa retorque ng head?
    sa pangalan pa lang ng mga services na yan...tyak ko...mahal bayad dyan
    may talyer ka ba 4JGtootsie? nakaka worry yung case ni dpackager considering na model 2000 lang yung hilander nya, 1 year lang agwat sa 01' xto ko.
    Jun 2005
    Quote Originally Posted by rsnald
    hay natapos din, its the "oil cooler" yun nga ang culprit.... pinapalitan ko na dahil may tumagas na langis sa oil cooler mismo na dapat water lang ang dumadaan dun... i buy at pasay the damage part at 5800, hindi kaya gawin at hanapin ang butas ng mechanic eh + 300 labor...
    anyone who knows why this happens?
Oil in Radiator...
