Results 1 to 12 of 12
    Jun 2004
    hi guys,
    our 4x4 fuego with a 4jb1t engine has oil comming out of the turbo. anyone here know of a shop that can fix the problem. thanks.
    mintoy
    Mar 2003
    sir sa central diesel in Quezon Ave., i've inquired before because mine is leaking too, estimated price was 35-40k, i just can't remember if they included the labor; mahal daw kase talaga ang OEM repair kit; mine is still leaking until now and has done so for more than 50k KMs now, parang hindi naman kase nagbabago, and they said your turbo could use a little lubrication.
    unless you see a change in the performance or it gets really smokey, i say you leave it as it is sir; and if it has finally given way, get a surplus 4jb1t with a working turbo and just use the engine for parts (was also advised on another thread). somebody said a brand new turbo unit will set you back 90k.
    Quote Originally Posted by BeetOls View Post
    +1 mahal talaga ang turbo kahit kit lang. I recall a 4d56 kit costs 12k. kung hindi pa mausok on IDLE after a long heavy run. then puwede pa yan...
    Jun 2004
    thanks guys for your inputs. i didn't realize the repair would be that expensive. i will try to pass by speed lab and phil diesel and get an estimate from them.
    as for the idling. it doesn't change even after a long drive. and the engine is not loosing any oil. so i will keep your recommendations in mind. thanks.
    what part of the turbo does the oil go out? picture would help
    Jan 2008
    Have you tried disconnecting the PCV tube?? Your turbo system may not be leaking oil at all and may possibly getting oil from the PCV tube.. OIL MIST from the engine is being sucked by your turbo...then it goes to your intercooler (if equipped) then to your intake manifold..
    Quote Originally Posted by mintoy View Post
    Mintoy and Beetols,
    Bring it here sa Central Diesel and I will see what I can do.
    Central Diesel 4113711 to 13 Ramon
    Jun 2004
    Quote Originally Posted by 4JGtootsie View Post
    Mintoy and Beetols,
    thanks bro. i will bring it to your shop. after da xmas season. ipon muna ako ng budget
    Jul 2003
    hi guys,
    mintoy
    Try mo sa SPEED LAB eto link http://www.speedlab.com.ph/products/...ntercooler.htm
    They have turbo intercooler din na brand new na 4 sale check with them kung pwede dyan. Tapos balitaan mo nalang kami.
oil leak in the turbo of 4jb1t
