Results 1 to 15 of 15
    Oct 2009
    Mga sirs, good day!
    Baka may recommended shops po kayo na gumagawa ng speedometer at odometer? Biglaan kasi na hindi gumana yung speedometer & odometer ng XTRM ko.
    TIA
    Quote Originally Posted by nelS View Post
    Mga sirs, good day!
    TIA
    if your vehicle uses a speedometer cable, i suspect it just broke. replacement is not too difficult and not horribly expensive. have it seen by a mechanic, sir.
    Oct 2009
    Thanks sir. The odometer is working in reverse because the digital counter has measurements. Possible po kaya na speedometer cable pa din ang cause?
    Mga sirs, good day!
    TIA
    Hindi ako pamilyar sa car mo, but I've another experience sa innova. It's odometer is running but the speedometer is not. The whole instrument cluster unit was replaced by the casa under warranty.
    Dec 2015
    It's the sensor underneat, near the transmission. My crosswind had the same experience, went to casa for replacement. Medyo malaki nagastos ko. Try going bringing it to banawe or evangelista, baka mas mura.
    Sent from my Mi 4i using Tapatalk
    Oct 2009
    Hi guys. Up ko lang ying thread, mukhang instrument panel ang sira ng crksswind ko. Nagpalit ako ng sensor pero hindi pa din gumana. Asko lang baka may alam kayo na bilihan ng panel na mura lang.... thanks.
    the entire instrument cluster pod?
    try the evangelista and banawe cathay centers, for used ones.
    but there's no guarantee that all dials and lights will work. you probably have to test them all, first.
    but perhaps you should have an auto electrician/mechanic, see yours, first. baka ma-buhay pa niya.
    Oct 2009
    Thanks. Yung speedmeter and odomerer lang ang hindi working. The rest are working.
    Apr 2009
    yung sa akin nasira speedometer turned out sira yung 'motor' ng speedo have it replaced kinahoy yung part na yun. nung una akala ko yung speed sensor bumili pa ako. yung sayo probably speed sensor, speed sensor gear or wiring sa panel, kasi sabay nasira. madali lang palitan pag speed sensor nasa ilalim sa may transmissioin parang nagpalit ka lang ng ilaw hehehe. kung sakali speed sensor sira benta ko na lang yung nabili ko kahit 1k, d ko nagamit.
    Oct 2009
    Quote Originally Posted by anthon05 View Post
    Thanks sir. Nakabili na din ako ng speed sensor. Kaya lang nung kinabit ng mechanic ayaw pa din gumana. Sabi baka yunh instrument panel na ang may diperensya...
    Apr 2017
    mga sir bago lang po aq dito. ask ko lang po if may gumagawa po ba ng dashboard? un crosswind xt 2001 ko po kasi humihinto un speedometer nya sa 40 eh pero un odometer nya po tama nmn.
    TIA
    Apr 2017
    Sir bago lang po aq d2 nrerepair po b ang speedometer kasi un crosswind q po humihinto un speedometer reading nya sa 40 kph eh, pero tama nmn po and data n lumalabas sa odometer ko.
    if nrerepair xa bka may marecommend po kau slamat
    Apr 2009
    Quote Originally Posted by Em Naval View Post
    narerepair yan yung sa crosswind ko pinaayos ko sa J6 sa BMA QC. may kamahalan lang. specialized nila yang
    instrument panel. from banawe right ka ng BMA papuntang kitanlad makita mo shop J6.
    ^ magaling nga daw ang j6.
    Iyong digital cluster gauge ng fd ng mga team fd peeps pag may problema jan ang puntahan
    Jan 2010
    mga nasa magkano po gastos? yung speedometer at odometer ko eh ilang taon nang sira. yung rpm naman, nagloloko, minsan gagana minsan hindi, or sasagad sya sa dulo at babalik na lang sa zero pag pinatay makina. isuzu xtrm 2000 model nga po pala gamit ko
Odeometer & Speedometer Stop Working
