Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
    Quote Originally Posted by baby_scar View Post
    sir. i have brake light. brake fluid in the reservoir. what is float connection? clean speed sensors? im not sure kung malinis pa ung brake fluid.. wala po ung dmax dito po. nasa province po. have u encounter this problem? basta ABS, handbrake and airbag lumalabas kung tumatakbo. para after a few seconds or minutes nwala ung signal tapos balik na naman
    Once napundi 2 bulbs or nasira ang brake light switch or naubos brake fluid or mababa ang vacuum ng hydrovac ABS warning can be triggered. Speed sensors are magnetic, accumulation of metal particles will inaccurately send wrong signal to ABS module.
    Aug 2009
    Quote Originally Posted by 4JGtootsie View Post
    sir. dati po.. minsan umiilaw po ung brake light after a sudden stop..you should add another force to the brake bago mawala yung brake light sa likod na ilaw.. what is speed sensors, saan yun? syensa na po - km reading po un? when i return to our province i will try your suggestion. palitan ko nalang ng bago fluid - bleeding. baka ito na ang dahilan. so that the signal will not disturb while im driving.
need help urgent (dash warning lights: all lit up)
