Results 1 to 3 of 3
    Mar 2007
    Isuzu Crosswind XTO m/T is my unit guys...
    Guys need your help again i have this problem before na matigas ang clutch upon pressing the pedal and now na solve na!!!
    1.now got this new problem again!!! Me oil leak sa pagitan ng transmission and engine at nababawasan oil ng engine ko so meaning oil seal is damage or worn-out....
    2. Open transmission and found out nga na me tagas sa me crankshaft oil seal. replace the oilseal said by the mechanic.....
    ** Upon replacing the oil seal observe and nothing is fixed parehas pa din me leak pa din. We already use the original oilseal of 4ja1 casa pa binili....
    [SIZE=4]***to cut it short, the question is me oilseal pa ba sa loob aside from the outer part??[/SIZE]
    Aug 2005
    bka ung crankshaft end cover plate masama na ung gasket, jan din mismo nkakabit ung crankshaft oilseal at notorious din ung oilpan gasket. pwde rin ung oil seal ng tranny pero bhira yan unless 200T+kms ang odometer mo sir
    Dont put too much oil especially kung may sign ng mataas na crankcase pressure. Check also your cylinder head gasket for oil leaks.
Need help!! oil leak at bell housing
