Results 1 to 10 of 10
- Mar 2007
- 12
July 12th, 2007 02:18 PM #1its been a year since this problem persistently occurs. i cant start my isuzu fuego 4x4 2004 during morning UNLESS I PRESS DOWN THE ACCELERATOR PEDAL. Nobody in the isuzu knows how to troubleshoot this. Even any local nearby auto repair shop cannot fix it. Please help me.
July 12th, 2007 04:09 PM #2
sir, i think wala na fuego sa 2004 kc dmax na lumabas dat tym...
maybe sa injection pump... or sa throttle
July 12th, 2007 04:53 PM #3
One click ba siya when you press down the pedal?
Did they check the solenoid cutoff switch?
Fuel filter?
Do you see any leaks on the injection pump?
Have they tried bleeding all fuel lines?
- Mar 2007
- 12
- Mar 2007
- 12
July 14th, 2007 11:58 AM #6[quote=4JGtootsie;853866]One click ba siya when you press down the pedal?
Pag click ko at ayaw mag start I press down the accelerator and then tuloy tuloy na sya
Did they check the solenoid cutoff switch? That I don't know. Thanks for that. I will inform them to check it.
Fuel filter? Yes, every 5000km ako nag papa PMS
Do you see any leaks on the injection pump? Wala pong leaks
Have they tried bleeding all fuel lines? yes
- Mar 2007
- 12
July 14th, 2007 12:01 PM #7
- Jan 2015
- 1
January 14th, 2015 12:23 PM #8
January 14th, 2015 01:01 PM #9
maybe may leak sa fuel line. bumababa ang krudo pabalik sa tangke. bomba mo muna ang fuel pump before starting the engine. if it works, fuel line leak.
January 16th, 2015 08:51 PM #10
bleed back condition. probably sa may priming pump mismo. yung o-ring inside the pump or yung flap valve na nasa loob din ng pump. another source of an air leaking is yung drain plug ng filter/sedimentor. pero you may want to retighten all hose clamps or replace the rubber lines baka malutong na.
TS, ganun din ba problem kung full tank or near empty?
