Results 1 to 18 of 18
  1. #1
    guys this morning lang ginamit ko pa yung crosswind.. pag uwi inoff ko na yung kotse..
    nung gagamitin ko na ulit ayaw na mag start :|
    kahit click wala.. pero malakas busina , ilaw , radio... kakapalit lang ng battery nito 1year ago..
    ano kaya problema?
    btw automatic transmission yung crosswind ko..
    *additional info
    ang suspect ko yung transmission sira.. kahit ilagay ko sa P yung lever tapos naka down ung handbreak gumagalaw yung kotse.
    may sira kaya yung transmission?? kasi hindi mag sstart yung kotse pag parang naka neutral yung kotse
    Jun 2006
    1. make sure transmission is in park
    2. Try to jump start the car.
  3. #3
    paano ko ilalabas yung kotse nasa garahe? pwede bang itulak to?
    sir nasa park yung transmission ko.. paki basa update.. may something sa transmission ko eh.. yung ata sira
    *plus parang nag sslide na lang ung lever kahit di ko pindutin ung button when changing N to D
    Oct 2011
    nag cr-crank ba? kung nag cr-crank pa, mahina na ang baterya, kung totally hindi, check mo starter baka may loose connection doon. HTH.
    WBR,
  5. #5
    hindi po nag ccrank.. pag try ko i-on nag off lang yung radio tapos walang click sound..
    Jan 2009
    Sir pa-check mo yung transmission mo. Mukang hindi sya nag-eengage or sira ung locking system nya on each lever position. And tingin ko parang naka-hang sya nyan. Kasi suppose to be hindi mo malalagay ung lever from neutral to drive and from neutral to reverse without pressing the safety lock button. And one more thing, hindi talaga magi-start ung automatic transmission na sasakyan pagka hindi naka-locked either sa neutral yan or park position. Pero busina, radio, lights, etc. bubukas sya pwera lang talaga ung engine pagka ganon..
    Aug 2010
    bro, based in my experience starter yan solinoid, kung kaya mong irekta yun line papuntang solinoid mag start yan kapirasong auto wire lang, ginawa ko yan nasa malayong lugar kasi ako inabot, pero nasa garahe ka na ipagawa mo na..
    normal yun pag galing ka sa R with/out pressing the button pag hinatak mo yun lever ang bagsak niyan sa D except pa balik ng P..
  8. #8
    ^ thank you sir
    pero i think sira talaga nasa transmission.. kahit nasa park yung lever tapos ibaba ko yung handbreak gumagalaw yung kotse.. may tama nga ata yung lock sa transmission
    starter or yung transmission lang talaga.. ipapatingin ko na mamaya
    Oct 2011
    cge balitaan mo kami kung ano ba ang talagang sira nyan.
    Jan 2009
    Sir pa-check mo ung transmission mo. Mukang hindi sya nag-eengage or sira ung locking system nya on each lever position. And tingin ko parang naka-hang sya nyan. Kasi suppose to be hindi mo malalagay ung lever from neutral to drive and from neutral to reverse without pressing the safety lock button. And one more thing, hindi talaga magi-start ung automatic transmission na sasakyan pagka hindi naka-locked either sa neutral yan or park position.. Pero busina, radio, lights, etc. meron sya, engine lang talaga ung wala pagka ganon..
  11. #11
    Quote Originally Posted by Sure Fire View Post
    yes sir nabasa ko na yung post niyo. yan din ang nasa isip ko kanina eh.. kasi kung starter yun siguro naman may click na sound ako maririnig diba. yung Parked position nung transmission busted ata.. its acting like Neutral :|
    May 2009
    check transmission. it could be in any gear except Park and Neutral. A/T usually have a Neutral Safety Switch cutting off the Starting/Ignition Circuit if the transmission is not in Park or Neutral. quick check on the cable connections (lever to transmission) may reveal a simple problem. hth
    Jan 2011
    brod, reset mo ang emergency button ng car alarm. nasa ilalim ng dashboard. kulay red yan at maliit lang. anti-theft system ng sasakyan natin yan. sa driver side, may maliit na slide cover ng left side mo, pagbukas mo, kita agad yan. nangyari sa akin yan. sabi ng mekaniko sa isuzu, tranny problem, ayaw ma detect ang park. buti nalang, sabi ng electrician, anti-theft system lang. its always a good thing to ask for 2nd, 3rd opinion.. hehehehehe
    Jan 2011
    in case, di mo makita yong red button na sinabi ko, check your manual regarding anti-theft button, refer to your manual.
  15. #15
    guys im sure transmission to.. nag bblink yung CHECK TRANS na icon dun sa dashboard eh.. paano ba tingnan yung sira nito
    May 2009
    check the quantity and quality of your ATF.....then
    check also the sensor if loose or corroded.....
    if everything checks out, a quick scan on the stealership might confirm the problem......
  17. #17
    guys naayos na yung crosswind.. may cable lang na natanggal from the transmission ) 200 petot lang bayad
    salamat sa lahat ng nag reply
    Oct 2011
    cable lang pala. okay sir.
ayaw mag start nung crosswind urgent help..
