Page 49 of 51 FirstFirst ... 3945464748495051 LastLast
Results 961 to 980 of 3710
    gps locating device or for navigation?
    Oct 2017
    navigation po
    owners manual nandian lahat required fluids...
    acehardware or similar shops have choices...
    for the coolant, its either green or red.. peak is a good brand. mixture dapat...why? you want the rust inhibitors
    brake fluid? dot3 ..any name brand.
    engine oil: learn which is required sa owners manual. pretty sure its of the 15w40 variety. 5000km for the mineral oil. check level every 2weeks..
    Dec 2015
    Guys baka may
    Softcopy kayo ng owner's manual ng sportivo or ng crosswind.
    Jan 2011
    pwede ang HU 2din sa crosswind. marami na ang nagkabit nyan. cut ka ng kunti sa aircon louvers. pasok ka sa team isuzu pilipinas FB page. marami kang makita doon na gawa na. na post nila.
    Sent from my SM-G610Y using Tapatalk
    Jan 2011
    ito yong sample.
    Aug 2017
    Hi guys..pag ba may usok sa dip stick eh blowby na agad?sa top cover wala naman usok na lumalabas..di din nagbabawas ng langis..
    Sent from my CAM-L21 using Tsikot Forums mobile app
    Apr 2009
    Quote Originally Posted by Edric_24 View Post
    Blowby na yan. pero mas maganda pa check mo sa mekaniko. kung
    malakas pa hatak at yung usok kaunti lang pagtyagaan mo muna.
    change oil mo lang every 5km palit lahat ng filters.tagal pa gamit niyan.
    Jan 2011
    normal lang yan sir. pag sumusuka ng langis ang dipstick mo, yon ang blow-by na talaga.
    Aug 2017
    And saan po ba location ng pcv valve ng xto 2001..tsaka ano ba hitsura nito?thanks..
    Jul 2010
    Mga Sirs gusto ko lang magtanong about sa 2013 crosswind ko bigla na lang hindi gumana hazzard lights. Ang signal light left and right kapag naka off ang engine hindi rin gumagana pero kapag naka on ang engine gumagana lahat ang signal lights as in okey pero kapag naka hazzard nawawala signal lights. Ano po kaya problema? Thanks po sa sasagot.
    Apr 2009
    Quote Originally Posted by tolits777 View Post
    pa check mo sa auto electrical shop. most probably may grounded yan or
    bad connection. paayos mo agad yan baka may madamay pa ibang electrical parts.
    Aug 2017
    *anthon
    Thank you..malakas pa naman ang hatak..yep, alagaan ko tlaga kc gusto ko dn magtagal sa amin itong crosswind. Mura kasi diesel kaya nagpalit ako ng sasakyan..kaya pa dn kahit paahon ng full load..nakaka 3500 kms na ako, pero di pa naman need mag top up ng langis..salamat sir.
    help. nag stuck up sa 1st gear ung kambyo. kahit na ka patay na makina ayaw parin maalis. pero tumatakbo parin pag inapakan ang clutch. ano po kaya nasira? tia
    Apr 2009
    Quote Originally Posted by mr.xtraordinary View Post
    Na stuck up clutch disc mo kumapit na sa pressure plate. huwag mo ng gamitin paayos mo na.
    Aug 2017
    *shelu
    Thank you..Ü
    Aug 2014
    Battery replacement lang cguro yan kung nadadala naman sa tulak ay nag eestart....
    Sent from a mobile device.
    Jul 2017
    Salamat sa mga reply boss. Nag unlock daw.
    Shut off valve ang problema pero na replace na.
    Shut off valve cost : P850
    Jan 2018
    Hello! Bago lang po ako dito. Bumili po kami ng Sportivo last year and napansin ko po today sa ilalim ng engine parang may part ng cover sa engine naputol. Should I be concerned about it or okay lang na iwan lang.
    Here is the picture. http://oi65.tinypic.com/2n9kqav.jpg
    the engine block is solid. that looks more like a bracket.
    im curios how often do you do the oil change? are following isuzus recommendation?
Isuzu Crosswind Owners Thread [continued]
