Results 1,951 to 1,960 of 3710
- Feb 2012
- 5
February 20th, 2012 02:56 PM #1951Hello fellow owners of Isuzu Crosswind. I own a 2002 Crosswind XUVi AT. Nabili ko ito last December 2009. Ok naman siya so far pero kahapon bigla na lang siyang nawalan ng power. While i was driving my Crosswind sa SLEX Mamplasan bigla na lang namatay ang engine. Tinabi ko muna siya. After several attempts to start the engine, umandar naman ulit. Pero nuong papasok na ako ng Carmona Exit, namatay ulit ang engine. Napaandar ko naman ulit hanggang nakauwi ako ng bahay. Wala namang open na shop sa area namin in Binan, Laguna kahapon kaya hindi ko na pa check-up. Fuel filter po kaya? Ano po kaya ang problem? Salamat po.
- Nov 2010
- 14
February 22nd, 2012 03:18 AM #1952Nangyari na rin po sa akin yan, same 2002 XUVi AT. Try nyo lang po ipa linis yung water separator at palitan ung fuel filter.
February 22nd, 2012 10:27 PM #1953
Maintenance Time
Before:
After:
Up in the air:
February 22nd, 2012 10:29 PM #1954
DLAA Fogs from Hotrod, installed by Jemson:
- Feb 2012
- 5
February 24th, 2012 09:22 AM #1955
February 24th, 2012 02:17 PM #1956
Paps, this also happened to my 2005 XUVi A/T, after replacing the Fuel Filter and cleaning the Water Separator, namamatay parin ang engine. So what we did was to draw down the fuel tank and drain all the remaining diesel. Presto.... ang daming sludge or putik sa loob. As per my mechanic, possible culprit was the use of different brands of diesel and dirty service stations. Kaya ngayon, I only fill-up my tank in one station if possible then using only one brand... hth
- Feb 2012
- 1
February 24th, 2012 03:47 PM #1957pahelp naman po mga sirs, newbie po, my brake indicator sa dashboard is on off sya, minsan dimly illuminated. nakababa naman ang handbrake ko. ano po kaya problem nun. napansin ko rin maitim na brake fluid ko. pwede po kayang yun ang reason? or switch something. I'm planning to have the brake fluid changed bukas. any suggestions po kung saan ok magpableed? pasig cainta area po sana. 2010 pa ata huling change ng brake fluid nya. TIA
- Aug 2005
- 18
February 25th, 2012 04:31 AM #1958Mga Sir, newbie din po. Patulong po ulit. Last end of Dec. po yung 1.5K pms ng XUV ko. Base sa pms checklist, next pms is 5k OR 3months whichever comes first. Di gaanong nagagamit so mauuna po ung 3months. Tanong ko po, since nasa labas po ako bansa pwde ko po bang dalhin sa casa after 6months. Salamat po in advance.
- Feb 2012
- 5
February 25th, 2012 06:55 PM #1959
February 26th, 2012 12:08 PM #1960
First Team Isuzu Crosswind/Sportivo/Highlander Photoshoot.
Team ISUZU Photoshoot | Facebook
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
