Originally Posted by
ARB
hmmm.... happened to me before sa pick-up ko. i have some of the the same symptoms. try mo to leave the engine on idle, if namamatay after a while. also there will be times na ok siya then mamatay. but if you pump it mag stastart ba? my problem was the injection pup bushing sa front ng injection pump after the gear. they just changed the bushings and voila never happened to me again. or your could be the springs inside the injection pump putol na, have seen a lot of this happened on the 4jai engines but the symptoms are no power above 3000rpm, may hesitation, try mo to pa check for air leaks injection pump mo if the so called ignition coil (mayroon ba diesel ignition coil) is not the culprit.
