Results 1 to 10 of 50
- Jul 2004
- 14
July 20th, 2004 03:23 PM #1repost from DieselClub.org
I have an Isuzu Fuego at first was just stalling and having a hard time restarting the engine. I was able to take the pickup home but now the engine doesn't start up. Some mechanics that tried to diagnose the problem claims that its the injection pump. My relative is saying that it might be the engine already.
Does anyone here know of any diesel mechanic willing to service/diagnose my vehicle at home. I reside in Moonwalk in Paranaque.
- 10,620
July 20th, 2004 05:25 PM #3na check mo na ba glow plugs?
mag start ka muna dun, may redondo ba?
battery...
ignition...
troubleshooting 101 muna
para ma eliminate natin ibang factors at malaman natin ang cause.
- Jul 2004
- 14
July 20th, 2004 05:41 PM #4glow plugs are because the engine is already running before it stalls, after that comes the hard starting part. after restarting the engine, I would go a few kilometers before it stalls again.
battery is ok. meron siya redondo.
ignition problem once engine stalls. I have already bled the fuel line. Problem ko ngayon, hindi ko na siya ma start.
Any tips on checking power on the injection pump? All fuses kasi are ok. I have the 4ja1 engine. According to the wheeler's club mechanic walang power daw yun injection pump.
My dilemma is baka may tama na yun makina, piston ring, sleeve etc.
Gusto ko sana pa check sa diesel mechanic. So I know my next step, to have it towed to a calibration center or talyer pag engine problem talaga.
Meron ba may kilala dito na nag home service?
July 20th, 2004 05:42 PM #5
papa kimpoy,
ang alam ko po walang glow plugs yan... ang 4J series la na po yan...
basta ako bukas ako sasagot sa diagnosis na yan
July 20th, 2004 09:15 PM #6
check mo yung shut off sa injection pump. it might not be opening, may wire there it may be corroded or may tama.
Tsikot Member Rank 3
- Mar 2003
- 637
July 20th, 2004 09:55 PM #7check mo yung magnetic valve(not sure sa name pero may magnetic sa simula) ng fuel pump yung sa hyundai grace namin ayaw magstart pero may redondo tapos yun pala ang sira. hindi ko lang alam kung meron din magnetic valve ang fuel pump ng isuzu engines. hth!
July 21st, 2004 04:41 AM #8
pag symtoms ehh malakas ang normal idle pagka nas start, tapus pabagobago andar atsaka madals ibakulay usok, parang hilaw malamang dibumabalik mechnism dun sa injector..hehe..antayin natin mga doc dito hehe..>>
July 21st, 2004 09:36 AM #9
gandang topic nanaman ito san post na si isuzu doc (buknoy2003xuvi).
sa akin dati experience ko nagwarm up ako ng makina papasok ako ng opis ng papaalis na ko bigla namatay makina then di na mag start pero malakas redondo so check ko lang un fuse 1 fuse busted yun yata yun papunta sa makina so change ko lang ok na. check mo continuity sometimes para syang ok pa fuse pero busted na pala.......
- Jul 2004
- 14
July 21st, 2004 02:40 PM #10meron ba ECU ang 4ja1? I'm planning to test the injection pump by directly connecting it to the battery. I haven't really examined the injection pump, is it just a power wire or are there also wires for sensors output?
Traffic!
