Mga ka tropa, nagpalit ako ng timing belt 4JG2 ko (Subic), umiba ng andar, gumaspang. May play daw injection pump sabi mechanic. Available ba Injection Pump Repair kit? Where can I buy one? Any comments out there? Thanks.
bro I doubt it. Naiba timing nyan or sablay pagka-kabit nung timing belt. Kung may problema injection pump mo naramdaman mo yan before you changed the timing belt. Kung IP talaga problema bring it sa Zexel sa Marcos Hiway. Magaling dun.
Kindly give exact address ng Zexel? Paki bigay na rin contact number if any. Thanks a lot bro.
Mga bro kc im havin problems with my bighorn lage nagffrozen yung airconditioning system nya...pinalitan k n yung drier and general cleaning n rin but still ganun p rin....i dunno if theres something wrong with the compressr or yung sa sensor....zexel yung brand nya. anyone who has an idea? tnx mga bro!
wait mo yun post ni gary alam ko nag kaganyan din yun unit nya before si master pajero ang gumawa. parang baliktad yata pag kakabit ng blower or yun xpansion valve ..........Originally Posted by al00399
Sir, baka naka recta ang compressor. Hindi nag rerelease pag malamig na o hindi tama ang expansion valve na ginamit.Originally Posted by al00399
ei guys p2long nmn,,i have an isuzu bighorn from subic..ok nmn xa tlga..but ung problem is pag 2makbo na ng malayo tas pnatay engine hirap na xa mg start mnsan aantayin ko pa lumamig ska xa mgstart...sa umaga bilis nya mgstart..ok nmn alternator and batteries pti starter..cnu po nkakaranas ng gnitong prob sa knilang bighorn or trooper..tips and advice nmn po..tnx god bless!!!
bro baligtad sya pag mainit hirap start.
yung sa prado ko after isolating all the problem nung mechanic dumatin sa point na yung electric spill valve ng injection pump ang problema at pinalitan. inuulit ko lang ha, dami muna tininingnan ng mechanic(like removing the pcv ang see if malakas ang labas ng hangin, etc) bago yun ang nalaman. humihina ang bigay ng crude pag uminit na raw makina.hth
bro ano yung zexel n yun sa may marcos highway? gumgawa b cla ng aircon dun ng bighorn? tnxz pre!
where can I get the timig belt for the JDM 4jg2? Saan kaya or sinong mechanic ok magkabit kaya nito?
Mga bro sino kaya may service manual/owners manual sainyo ng bighorn?Tnxz!
saan kaya or sino magaling magpalit ng timing belt ng 4jg2 engine? pwede ba pa share naman ng service manual/owners manual ng bighorn nyo? thanks.
matagal-tagal na tong tanong na to pero sasagutin ko pa rin baka makatulong sa iba.Originally Posted by mcbry
I had the same problem with my bighorn before. if your bighorn has the electronic climate control panel the problem could be the thermostat located on that panel. apparently that climate control panel uses cabin temperature to switch-on and off the compressor. during conversion the wires could not have been returned properly or the electronics have been damaged.
What I did was deactivate the climate control and just installed a manual knob type thermostat. Problem solved pero yun lang nga aesthetic na lang yung climate control panel.
Another problem could be baliktad ang pagkabit ng expansion valve dahil hindi pinalitan ang evaporator nun kinonvert. dapat na sa left yata ang expansion valve and not the right side (pag left hand drive ang kotse kasi yung expansion valve na sa right side). I had to change my evaporator twice before I figured this out.
Ngayon malamig na sya pero problem ko is hindi maganda ang pagka sara ng firewall during the conversion na pag na sa highway ako my pumasok na hangin sa labas kaya hirap magpalamig ang aircon.
jai, did you ever fix yung firewall sa bighorn mo? i have the same problem kasi e. thanks.Originally Posted by Jai
