Page 1 of 4 1234 LastLast
Results 1 to 20 of 82
    eto po ba yun?
    2WD version
    ganda :D kelan kaya ako makakaron nyan? haaay
    eto pa..
    4wd version. pero bakit sa Thai Rung Union Car Company nakalista sya? binili ng isuzu yung design?
    just the same... ganda pa rin.
    Sep 2004
    The Thai Rung Union Car Company is credited as the actual creator and assembler of the Adventure Master.
    This beast reminds me of the Suzuki XL-7. Nothing special, IMO, since it's just a D-Max without the external cargo bed. Big in size, almost US-sized dimensions; a step backward in design and engineering, but that's just me. Pero okay na kaya ang handling nito? Noise suppression, suspension and parts availability? I've heard horror stories about Isuzu engines not being repaired due to high prices and scarcity of parts locally (kinukuha pa daw sa Japan kaya hassle).
    Will Isuzu be retaining the Adventure Master name for this model once it is distributed in the Philippines? If so, this may present a possible legal issue, with Mitsubishi already owning the rights to the Adventure name.
    para yatang underpowered... ?
    Engine
    Model 4 JH1 - T MAX
    Type 4-Cylinders, in Line, OHV, Direct Injection turbo, water cooled
    Displacement (cc.) 2,999
    Bore x Stroke (mm.) 95.4 x 104.9
    Compression Ratio :1 17.7 : 1
    Max. Power (kw/rpm) 88 / 3,800
    Max. Torque (NM/rpm) 245/2,000
    88 kw = 117.9 HP. malakas pa 4x2 trooper (160 HP) at 4x2 Dmax (130 HP).
    pero mukhang matulin yung 2WD/MT nila. eto ang FGR's nila
    Final Gear Ratio
    2WD/MT =3.909
    2WD/AT = 4.555
    4WD/MT = 4.555
    4WD/AT = 5.125
    rest of the specs ...
    http://www.thairung.co.th/English/Co...Technical.aspx
    if it's cheaper than the everest it will be a good buy. hmmmmnnn I seldom encounter people using Isuzu vehicles who had engine problems and needed engine repairs (karamihan suspension at exhaust problems). anyway it looks great! i hope the interior looks good too! :-)
    Sep 2004
    hmmm...not bad....maybe time to trade in the trooper..hehehhe
    Jul 2004
    7 seater ba ito?
    at least, with the body works done, it does not look like a d-max pickup with a carryboy cover
    definitely worth looking
    sana ibebenta yan dito :D
    hmmm...not my type...pasra siyang....caterpillar.herhehrerh...parang pinahabang ewan..pilit.
    that's just me.
    DMAX parin.
    parang papalitan na ni rsnald ang crosswind ng master adventure!
    parang trailblazer sa sideview.
    Signature
    Trend talaga sa Thailand yan, the Frontier and Strada have similar evolutions.
    117bhp is already at par with the Everest (and light years away from my Pajero).
    But the Nissan Xciter (derived from the Frontier) should blow the Isuzu's doors away as it uses the engine of the Nissan Patrol GU.
    Aug 2004
    Will Universal Motors import it, though?
    I wonder about the Adventure Master, though... is it filling a gap in the Isuzu range that does not exist? I'd like to see how they will market it between the Crosswind XUVi and the base 4x2 Trooper.
    I personally would have put my money into developing a new flagship Trooper off the D-Max chassis, and creating a wider range of trim levels for people to choose from.
    The Crosswind was developed from the previous generation Isuzu trucks. I don't think there will be a new Crosswind.
    The Adventure Master will be its replacement as it is derived from the newer DMAX platform.
    Then there's the Wizard/Mu/Amigo/Rodeo series that they sell in Japan and North America.
    * OTEP,
    Ehem.......
    that's a problem that am thinking of...
    since this isn't being assembled by Isuzu itself, how good would be the workmanship of the said "Thai Rung Union Car Company"?
    looks awkward to me. unlike the Everest which was decently executed, the body of the adventure master is just too long and forced fit. seems that almost no chassis modification was done to the d-max (to cut cost maybe?).
    Mukhang may natatagong pakulo si boknoy, ha.
    Crosswind on DMAX platform? :D
    OTEP,
    Wala ako alam diyan.... I invoked my right to self incrimination hehehehehe
    nye! pre... wish master lang ako :D hanggang wish na lang. :drool:
    master boknoy ...
    anong sikreto na naman tinatago mo?
    Wala,
    Wala ako alam diyan.... nananahimik ako....
    again "On the counsel of my attorney I decline to answer your question" hehehehe
    coil spring na daw yung rear suspension ng 2wd imbis na leaf spring? so can we expect a better ride?
Isuzu Adventure Master
