tsk....tsk....or your could be the springs inside the injection pump putol na, have seen a lot of this happened on the 4jai engines but the symptoms are no power above 3000rpm, may hesitation, try mo to pa check for air leaks injection pump mo if the so called ignition coil (mayroon ba diesel ignition coil) is not the culprit.
mukhang ganito na nararamdaman ko sa hi lander namin. hanggang 3000 rpm na lng kaya pero 120kph naman ang speed. ung springs sa injection pump po kaya un?
