Results 1 to 6 of 6
    guys need ur expert opinions kasi lumubog yung clutch ng xwind i checked underneath may leak, car wont start too. i called isuzu alabang and they don't have a tow truck ..gusto nila sa casa pa nila gagawin wala ring silang home service. paraÑaque area po ako..
    Quote Originally Posted by gedster View Post
    since sabi mo, hindi mastart...cant you say sa isuzu alabang na AYAW NGA MAGSTART KOTSE MO. so hindi mo madadala sakanila, obviously
    stucked up in gear? paano ayaw mag start? walang redondo? or naka stucked nga kaya kadyot instead na mag start? check your clutch fluid, punuin mo then bombahin mo yung clutch pedal.
    Bili ka ng brakje fluid at clutch slave assembly maski replacement basta recommended.
    Look for a mechanic maski hindi expert. Luwag, tanggal, palit, sikip then bleed lang yan.
    I also suggest you keep the old, papalitan mo ng kit for stand by for future need. I always have a spare in the car especially pag long trips ko.
    under warranty pa ba? hanap ka ibang casa, mas malapit mas mabuti kasi void warranty nyan pag pinagawa sa labas. kung tapos na warranty might as well sa labas ka na kumuha ng gagawa, tama si tootsie, hanap ka ng mechanic, mga gas stations may on duty mechanic, pasilip mo then bilhin mo yung kit needed + labor mo na lang si manong.
    May 2007
    If this is setup as a hydraulic clutch, then either the slave cylinder is bad, or the master cylinder to the clutch system is bad. Easy fix.
help...clutch ng xwind lumubog
