What is the right tire psi of suv with a tire size 265/70 16".
Posted via Tsikot Mobile App
Look at your driver side door. Nakasulat naman yun dun.
But generally, SUVs/pickups have recommended pressures of 35-38.
:old::old::old:
+10 bro, saka asa sayo nadin yan kung anu mas komportable pakiramdam mo pag tumatakbo na sasakyan mo. mararamdaman mo naman yaan kung matagtag o pino ang ikot ng gulong mo kapag natakbo na sasakyan mo, kung wala sa gilid ng pintuan mo naka lagay yung satndard psi para sa gulong mo e sa may sun guard dun nalagay. maliban nalang kung na scrip na ang sasakyan mo edie mo talaga makikita yaan.
Thanks sir, bukas titignan ko sa driver side door.
Ako naman, sa 265/70 R16, 33 or 35 psi. Dyan mo lang laruin yun pressure.
The Driver's side pillar (not door) for the 2011 Alterra recommendation is PSI 26 unloaded and PSI 29 loaded.......important...these are "cold" readings.
However, I ride, mostly unloaded, on PSI 30 which gives me a more "sure-footed" feel for stability, and a major increase in fuel economy.
Personally, I find PSI 35 might be OK for pickups rear, but would recommend experimentation by yourself to find the "ideal" PSI for your personal driving style, roads usually travelled and comfort/fuel economy compromise.
Ciao!
Uncle Nick.
Minsan in kpa nakasulat sa driver side. But 30-35 should be the norm.
Generally, you should follow the door pressures. They'll give you the best comfort at the "unladen" pressure. If you are carrying heavy loads, use the "fully loaded" recommendation. This will give you better economy, too.
If the door sticker suggests a pressure under 30 psi (as Isuzu door stickers typically do), disregard and use 32-35 psi (minimum), as this is safer on the highway. Pressures under 30 psi can lead to tire overheating and blowouts when driving at high speeds over long distances.
Note that the door sticker is merely a minimum safe recommendation. If you don't mind a stiffer ride, you can go higher. I typically use 40-45 psi on my Crosswind's 235/70R16 tires. Gives better economy and better handling. If the pressure is too high, however, the front tires start to tramline on the highway, so adjust accordingly.
mga bossing.... 08 isuzu dmax 4x2 owner here.... nag worry nmn ako sa nbasa kong pwede mag overheat yung tires under 30psi on long driving... I maintain mine at 30psi lng kc... hindi kc kgandahan yung mga interior roads dito sa dvo plus i go to construction sites often. can somebody advise me on what pressure shud i maintaino on 265/70 r16 tires? i usually travel just around the city most days, do a long drive on weekends...
Ako sa 185r14c 32 - 35 Pero nakagay sa may pinto 26 front 36 rear. Para kasing flat tignan pag 26 :confused:
Sent from my LG-P920 using Tsikot Forums Mobile App mobile app
I think this recommendation is very good for a DMAX.
The trade-off of comfort loss is exceeded by the safety margin increase factor and significant fuel milage gains.
It is important to note that weather temperature is negligable. However readings should be done "Cold".
Cold readings mean the truck has not been driven when measured. Just a few miles of driving can very significantly increase the readings.
Ciao!
Uncle Nick.
