Results 1 to 12 of 12
    May 2011
    I own 2005 dmax ls and am experiencing problems na. My check engine indicator turns on then I lose power. Sabi sa casa change oil, change air filter, change ko din ang fuel filter but bumabalik parin ang CHECK ENGINE.. What will I do?
    Feb 2005
    From where are you located?
    Feb 2011
    Good day to all Troopers,
    My check engine light come and go for the second time, it's trooper 2002 LS. is this sign as early warning for an oil change?, trooper is nearly reaching the 5k interval, any inputs are highly appreciate, thanks.
    May 2011
    sir benz am from angeles city pampanga.
    Mar 2004
    *ts- i own a 2008 dmax. i had that too 2 weeks ago. what i did was drain the fuel from the water seperator valve at the hood. did it a few times.
    everything is fine now.
    by the way. another symptom. if in the morning you start your engine and you hear a clatter in the engine before it runs fine in warmup then there is air in your fuel system. and so bleeding it is what made my dmax run fine.
    hope this helps.
    Mar 2004
    update on this problem with check engine light and losing power. just sent my dmax yesterday to the casa. and the tech2 reported problem with the SCV/ suction control valve. replacement for the "modified" scv is P7990 ouch.
    Jan 2008
    nyek... parang din palang D4D yan Dmax... SCV din ang problem.... Denso system ba yan?? papalitan mo na
    Mar 2004
    not sure if its a denso unit. but all 2010 and up isuzu crdi, the SA said, is using that kind of modified scv. the reason was dirty fuel. thats why its adviced to change fuel filter every 20000 kms.
    May 2017
    Quote Originally Posted by jeng santos View Post
    Sir, My MuX has this problem and yung akin nagiba tunog ng makina and ang sabi sakin sa casa kailangan daw e check sa computer ang problema. Common po ba ito sa mga my isuzu? Thank you po
    common? first time seeing it... so its not common...
    Jun 2017
    Quote Originally Posted by Jan Bor View Post
    Have it diagnosed (for code error) first to see what's up. Mahirap mag 2nd guess ng ganyan trouble. You might end up damaging your vehicle more. HTH.
    Dec 2016
    good evening mga sir! i also experienced an issue regarding po sa check engine ng dmax ko. when i reached 100kph, check engine light is on. then once na pinatay mo yung makina, mawawala po sya. den when u reach again 100kph, iilaw po ulit yung check engine nya. but the rpm is stable naman. anyone who can help me po mga sir? thank you in advance!
    btw, dmax 2007 4x2 model po siya. 4jh1 engine.
    Sent from my SM-J710GN using Tsikot Forums mobile app
check engine indicator lights on..
