Results 21 to 40 of 60
    when oil consumption is up, blowby ang engine. sometimes, clog Lang yung breather hose adapter from engine to the hose
    Nov 2012
    Main reason people blank their EGR is to prevent soot/sludge build up in the egr and intake manifolds ..... But this build up takes years to accumulate ... Also isuzu engines aren't notorious for sludge problems. Bago pa MUX no hurry for an egr blank. Read more about then decide wether to do it or not.
    Sent from my LG-H950 using Tapatalk
    Quote Originally Posted by Tediber Ang View Post
    Sir not to ba a scare monger but soot does build up quickly at least in my case. 14 thousand kms from new 2012 montero. That is more or less a year of driving for me pag bukas ng egr meron nang significant build but not enough to throw a code. Used to gas up with petron diesel max then. Now it's unioil or shell fuel save.
    Aug 2004
    20yrs in business all my isuzu trucks never had any engine sludge related problems nor the L300s i had and have.
    Common rail engines are entirely different animals compared to old-school diesels. EGR issues afflicted the Alterra back when they delayed the implementation of Euro IV, I believe... which forced Isuzu to switch back to the older EGR systems. (this is secondhand info from Alterra club members during one of our Shell events... so I am not quite sure which years were affected).
    EGR gunking is a common issue with newer diesels like the ones in the Montero Sport / Strada and the Navara.
    Nov 2012
    Sir referring to soot build up in the egr valve of crdi engines. But I agree sa intake manifold assuming well maintained hinde ganun kabilis.dumumi
    Feb 2016
    Naka EGR blank ka sir?
    Nov 2012
    Nde pa ko naka EGR blank .... not in a hurry ... but i will do it sabay na oil catch can.
    Oct 2015
    EGR shouldn't be an issue if you do a lot of highway miles and drive it like you stole it when you can. A friend's EGR was remarkably clean when they opened it. It had 130TKm on the odo, most of them run on the NLEX/SCTEX. That engine lived all its life on Euro 2 diesel.
    With Euro 4 diesel I'm not sure if it will still be an issue even if you do mostly city kms.
    Jan 2009
    I had mine blanked. If any, I simply don't like the idea of my car breathing its own fart.
    Nov 2012
    Fully blanked ba sya ?
    Jan 2009
    Yes. Removed the EGR cooling pipe and covered the two open ports with thick aluminum blanking plates. The EGR valve itself is untouched and the computer thinks it's still working. But the port has been sealed and no exhaust gasses are passing through.
    I'm wondering if opening it up and connect it to a 2nd air filter would help reduce pumping losses. So, the idea is to allow filtered air to enter whenever the EGR valve opens up. There's a sort of 'proportioning' butterfly/throttle valve in the D4D that supposedly increases EGR ingestion whenever the EGR valve is open. Opening this port up should reduce pumping losses and further increase fuel economy. Haven't seen anybody do it.
    Nov 2012
    Thanks for the response ..... Removing the pipe seems a much much easier job than accessing the egr valve itself.
    Apr 2012
    see video posted by bro zix888 (gtv2011 ph) 2 yrs ago regarding the actual behavior of egr valve of a montero diesel engine during idle and when gas pedal is pressed. its in normally closed position during ignition then around 8 secs of idling, it will open and stay in normally open position. it will closed and open as the gas pedal is press.
    montero sport egr valve - YouTube
    it's interesting to see those mappings and reference documents
    Oct 2015
    I guess I don't need to graph out a friend's mux then. The video shows how the egr operates on a diesel engine.
    Jan 2009
    Thank you for the video. It's no wonder then why those Diesels produce a lot of black exhaust. And just the thought of the engine ingesting that in, it's just, well, tragic.
    I'm now even more glad I've blanked mine.
    Same here, bro.
    I planted a couple of trees for each of the rides we've blanked... hehehe
    _/_/_/
    30.9K _/_/_/_/_/_/_/_/_/_/
    Nov 2012
    I have a wifi obd2 but my egr readings seems always 0% ... I got my 2014 dmax 2nd hand but i don't think it's egr blanked as i do not see any modifications. Anyway i wanted to blank it myself ... And just needed an easy way to do it.
    Jan 2009
    Does it show 0% under any driving condition? It should typically open up while cruising at a constant speed.
    Nov 2012
    I noticed it was at 0% even at idle ..... Anyway i'll check it again. Don't like keeping the obd2 device connected always as it seems to heat up. And as i know the egr should be open at idle speeds and closes at higher revs.
EGR Blanking, is it recommended or not.
