help mga experts! i have a crosswind xto 01 with 88k in odo. nag auto on/off aircon niya every 5-10 secs or so. iyong iba rides ng in-laws ko hindi naman ganun kadalas engage on/off. i have the aircon inspected and cleaned ok naman daw. i have the mehanical thermosat sensor replaced (replacement lang, iyong fixed na). ganun pa din, medyo regular interval tik-tak na nga lang every 5 secs. what seems to be the problem? any similar experiences & solutions? tnx in advance
Sounds like a loose wire along the system specially that green wire. Not grounding because the compressor clutch grounds to the engine. It could be as simple as a loose plug or wire inside a plug not making good contact.
You would first remove every plug that you could trace out, and slightly bend the pins inside each one of them so that they would have more pressure during contact. Next would be a loose wire or crimp connection that you would also be loose somewhere along those wires.
i dont know ha...
but in our honda civic, about every 15 seconds aandar yung compressor... then patay for about 30 seconds...
actually depends on the thermostat... kung mas malamig... matagal aandar yung compressor, mga 30 secs... then sandali lang mamamatay...
seems normal naman. and dati pa 'to ganito...
i dont know... maybe its different with your crosswind...
it seems loose wiring nga. i removed the connection near the compressor clutch, and sinundot ko iyong pin sa loob niya. i reconnected it again and presto ok na siya
mga sir tanong lng po ako, bat bumabaho po ba pagpinaandar ko ung aircon tuwing umaga pero after 1-2min nawawala po.. bawal po ba mag spray ng perfume sa loob pag gumagamit ng aircon? 3 weeks old pa lng po ung car namin bago pa po..(sportivo 2008)
