Forums
Discussions
Events
Community
December 13th, 2004 09:11 AM
How does this new setup improve the suspension performance of the New Isuzu Crosswind? Would it be possible to replicate on other AUVs?
December 13th, 2004 09:29 AM
Shocks look stock... Could possibly be different rating/thickness on the leaf spring layers.
December 13th, 2004 09:34 AM
same with 2005 dmax, naka flexiride na din
December 13th, 2004 05:48 PM
Nilipat nila yung shock mounting ng isa sa bandang harap ng diff. Pwede rin naman gawin ito sa trusty welding shop. But you'll need to be sure there's an existing crossmember to weld on.
Probably the leaf springs had different spring rate and all add up to marketing hype.
December 13th, 2004 06:03 PM
pag sinisilip ko ilalim ng 2004 crosswind, halos parehos lang sya sa revo.. yung the way na nakapwesto yung shock absorber (bias mounted) is the same as the revo..
probably yung spring rate lang ng leaf springs ang nabago sa sportivo..
pero let's wait for other crosswind owners here
December 14th, 2004 10:14 PM
The shox are installed in such a way to prevent axle wrap. Typically this setup is use with leaf springs suspension.
December 20th, 2004 11:38 PM
mga pre, malakas kutob ko na gaganda ride if lagyan ng OME gas shocks. puede kaya?
December 20th, 2004 11:55 PM
repoman-yes crosswinds can be installed with OME shocks
December 21st, 2004 01:36 AM
I dont see anything different from the pix itself. Siguro yung reversed spring setup. usually AUVs have standard leaf springs.
December 21st, 2004 11:17 PM
tnx ARB for confirming. i have OME on my strada 2000 suliiiiiiit! pag ilagay yan sa sportivo malakas kutob ko nakangiti driver at hindi pagod
December 22nd, 2004 03:04 AM
repoman875 , pasakay naman! para malaman ko kung ayos na ayos! :D
December 22nd, 2004 12:55 PM
para sa akin mas malambot na ang ride ng crosswind kesa sa old hilander series. this was before the upgraded suspension setup.
December 22nd, 2004 10:50 PM
Is there an OEM for REVO? Do you think it will improve the ride? Advise please.
December 22nd, 2004 11:36 PM
OEM for Revo will always be available at your suking casa or Toyota authorized supply store. :D
