Page 10 of 10 FirstFirst ... 678910
Results 181 to 192 of 192
    up ko lang, since walang built in aux fan ang crosswind,
    hindi naman siya lumalagpas ng 1/2 mark. no need ba to
    put an aux fan? or meron na rin sa inyo na naglagay for
    extra cooling. tnx
    Quote Originally Posted by phat_azz View Post
    ano yung itsura ng tulo nung radiator leak? either that o yung power steering fluid problem yung pinost ko above. yung water separator problem lumalabas lang pag long drives... pag dinadala namin sa baguio or bicol.
    yung radiator leak, makikita mo lang usually pag umaandar yung makina while idling, at saka pag mainit na yung tubig sa loob. usually dapat pressurized yung tubig sa loob para lumabas yung leak. pag meron leak radiator mo kahit di umaandar makina, itakbo mo na sa pinakamalapit na radiator shop yan at malapit ng manganak..este mawalan ng tubig yan dahil siguradong malaki na yung crack or butas ng radiator mo. look under engine bay while idling, minsan mahirap makita kung maliit pa yung leak. mapapansin mo lang palagi na nauubos yung tubig sa reservoir kaya mo malalaman na may leak.
    yung power steering leak naman, inspect the ends of the rubber hose kung namamasa with a dark fluid. pwede din dun sa may dulo ng power steering gearbox mismo, pag laging parang basa or magrasa, sigurado may leak yun. you need to replace either the power steering hose or buy a repair kit for the power steering gearbox, or both to eliminate this problem.
    Quote Originally Posted by center
    ano ba ang mga 1st gen xwinds?
    yung early 2001, up to, i'd say early 2002 yata ang first gen. makikita mo yung rubber molding ng rear windshield, yung old style na naka-angat pa yung rubber na nakapalibot sa rear windshields/glass panels pati na rin yung nasa sides na glasspanels sa likod. after that, pinalitan nila yung style, wala ka ng makikita na rubber na nakalabas, yung flush type na ginawa nila. January or Feb 2001 yata na launch yung unang crosswind, 715thou lang yata yung top-of-the-line nila (XTO matic turbo DI).
    * xto,
    pre, kung ikukumpara mo yung radiator ng xwind, malaki sya kumpara sa kotse, or fx or even sa old hilander. Sanden yata yung sa old hilander. More than enough na yung surface area nung radiator to cool the cooling water, kaya di mo na kelangan ng auxillary fan. wala pa kong nakitang naglagay ng aux fan sa crosswind. saka mukhang mahirap lagyan dahil malikot yung radiator natin on startup and engine shutdown.
    Quote Originally Posted by rsnald View Post
    * xto,
    tnx rsnald, kala ko ako lang walang aux fan nabasa ko kasi yung
    thread about overheating which may result to gasket leaks and cracked
    engine block etc.
    buhayin ko ang itong post na to 3 years after the last post and after more than 100,000 views.
    mukhang na solved na nila yung problema sa radiator (or nanahimik na lang yugn may mga problema sa radiator?)
    in any case, wala nako masyado nabalitaang problem, I guess the just decided to solve this problem quietly either through the dealership replacements or thru the use of stronger radiators from Denso.
    Last problem I had w/ my radiator was a leaking part of the cooling fin itself due to wear and tear and corossion. niremedyohan na lang nung suki kong radiator guy. Nagtanong ako ng brandnew radiator, 6 thou daw yung fit for the crosswind . Another thing to watch out for is the water pump itself. for those xwinds out there approaching or past the 100 thou KM mark, the shafting of the water pump will eventually wear out and you'd have no choice but to replace the water pump. Lucky for us, merong replacement na mura mura although kelangan diskartehan yung mounting ng radiator fan. In case meron magpapalit sa inyo, just tell the auto shop na yung water pump for the old isuzu hilander. fit na fit yun sa mounting bolts ng crosswind.
    Feb 2005
    From my knowldge, the "overheating" problem of the Crosswind was already solved way back 2004. So if you have a unit 2005~newer, you can sleep soundly. (unless your room's window is beside the garage at kapag pinaandar yung Crosswind mo, parang may NKR kang katabi. hehehe!)
    Sep 2009
    My friend mentioned about this overheating concern while i was looking for a crosswind.
    Luckily when i got my XTO, the radiator had already been replaced.
    Tanso na 2-layer, so sureball na na walang overheat basta alaga na lang.
    I was told by a crosswind owner the original one daw is plastic lang daw and single layer. m not so sure though maybe that is the cause of it being brittle. Anyways with what i mentioned na alaga siguro it really needs checking everyday or everytime you go load fuel on gasoline stations. I dont mix coolants on it anymore since with my experience with my ex-lancer, coolants tend to be a double edged sword, with proper care it helps manage the temp of the vehicle but in case THE UNEXPECTED arises, like electrical issues with the Fan, or Radiator hose leaks and the driver wasnt able to notice it then the radiator dries out - the coolant deposits eats up the radiator coils/tubes (it acts something like rust). thus the start of the radiator issues.
    Siguro only thing I can notice for now is the squeaking of the backseats, Door moldings in case malubak sa edsa. Are there any suggestions para mawala ung mga un?
    hehe
Crosswind's achilles heel
